Why campro engines fail on crank!!! Campro 1.6 vs 4g92p
chocolatesttarfish
1,041
68
PJ/BTU
any proton employees here..pls dont shoot anybody if ur mad reading this :biggrin:
normal use is ok...if gasak, then sorry...
agreed..i hv a piece at home waja campro 1.6..been using it for 3 years alrdy..so far it did it's job fine..but this engine is not for heavy duty..if u gasak then it won't last long..to me the most important thing is the service time punctuality..
speed2horizon,
thanks for the info bro..with ur kind of writing is enough to convince people not to buy Waja Campro :biggrin:
speed2horizon
2,798
334
1,683
speed2horizon,
Sorry if I am offending. But I really don;t mean it. Just wanna share what I see.:biggrin::biggrin::biggrin:
mark_15
250
2
y must not buy waja campro.....its a good car wut...hehe
speed2horizon
2,798
334
1,683
Acttually nothing wrong with WAJA Campro. Engine not to say problem la... Just that the design of the engine seems less durable.
But 1 thing I cannot tahan is the rear lights design.... Macam taaaahhhiii
mark_15
250
2
haha..that i got 2 agree wit u...huhuh....the old 1 is so much better...haha...but thank God la..my car 4 2 3 years edi in the drag scence but got no prob at all....real lasting my campro...
cyborgsabah
300
2
5,018
Afghanistan
The hole in the conrod bearing is not for oil entry. Almost all (if not all) crank bearings and conrod bearings oil supply is from the crank shaft it self. The hole is mainly for piston cooling.
Most aftermarket conrod do not have the oil hole. They can work without it..
The holes under the piston are for oil drainage from the piston oil scraper rings. It is never intended for oil supply to the rings..
I suspect what cause premature failure of the conrod bearing is the conrod and the conrod cap are not aligned properly.. proton bad machine work...
speed2horizon
2,798
334
1,683
Thanks for the information.. Appreciated the input.
Urm... If u realize, some aftermarket conrod also have oil lines fromt the crank all the way to the piston pin align right at the center of the conrod shaft. Cooling also.
And for every where the oils went through in a conrod and pistons, they are used as cooling and also lubrication.
And the improper conrod cap and conrod alignment leads to the crank failure where the protuded part of the conrod scraps along the conrod mount on the crank.
Being in the diecasting and molding industry for over 3 years, I know that die casting is loosing money due to the cost of die, aluminum melting machine, maintenance, fuels and remelting of the returns. But machining work are gaining. Machining work cost alot of money.
So, by saving the cost of machining, it simply means they save alot. Imagine 10,000 unit car/year. You'll have 40,000 unit of conrod and 30% spare parts in the market.
52,000 units of conrod produced for 10,000 car. To save RM2 in every conrod, they saved RM104,000/10,000 cars produced. But mana pergi..? Oppss... Sorry... Spoken too much.
rex79gt
742
98
Ngiao City
stil thinking to BOT my neo auto -.-
tigger5251
240
27
hehehe, costs saving, ended up consumer suffers....biasa lah....its a PROTON
tigger5251
240
27
no wonder alot proton nowadays, when pass tol, rather open door to pay tol......sked they wind down windows too much later kong.....why not do like the F50 style ? "KNOB WINDING WINDOW"
rex79gt
742
98
Ngiao City
even enzo is using manual windows juz to reduce weight
chrissyong
975
14
Any other comments/experience..?
i also saw many case campro engine,but the one serious case is a got one gen 2 just 1 month below 30k km,the main bearing jam then got one engine con rod break already,the engine head also is crack already,that time i forget to take photo,if got next time i sure take some photo to share with us,that campro engine really is no eye see+_+
speed2horizon
2,798
334
1,683
IT must be the misalignment of the conrod and conrod cap...
GoldenHawk
777
It's always an issue of QUANTITY vs. QUALITY. When will these people understand! :frown:
BTW, aren't the piston oil-lines for lubrication? I mean, the lubricant serves a cooling purpose too, right?
But then again, with assembly quality like that... :frown:
Reporting to you live from Tokyo (if a 2 hour delay is accepted). We made an exclusive trip to Top Secret Japan. There was a intimidating feeling of an underground joint as we pull up at the venue in Chiba lead by non other than Nezuka-San from Duke Racing Japan...
