What's in the OCT after 4 months?
gtiwtks
157
Drex,
Recently my arosp33d oct's bottom cover almost falled off due to the align key screw lossen and 3 out of 4 had MIA. Luckily check my car last weekend after heard some rattling noise. Took me quite some time to remove the oct in order to tighten back the bottom since it was located at hard to reach corner. Have to temporaly remove the align key screw on top to lock the bottom one. Look for replacement but can't find one. So, I called the arosp33d boss and he replace the screw for me foc.
My oct was installed where the valve rocker cover but disconnects the hose to the air-filter box. I sealed the intake ram pipe with nipple as told and i manage to catch some oil. Now i want to installed the oct between the PCV valve and intake manifold. But i forgot which hole is for inlet/outlet. Does it matter? Another issue is my oct was installed on my left part of the engine. No more place on my right. So the length of the pipe is quite long, Got any problem?
c-ground
311
3,016
Seri Kembangan
cground.fotopic.net
izso,
I just take the whole gauge/indicator off. Screwed the holes, use an oil seal made from fuel hose.
gtiwtks,
it doesn't matter which is inlet and which is outlet. Length ofthe hose is not an issue, the vacuum level is still the same as long as there's no leakage.
/Drex
e819
1,261
drexchan said:
No lar.. we hapily share what we know throught our website. Unlike someone who post something then ask ppl to PM for detail/diagram/etc.
i like his style..
nitrus
2,895
35
1,648
Wanna ask a super noob question ..
Will having OCT or those d.i.y OCT(fuel filter) increase ur backpressure slightly n make u loose abit pickup or something? hehehh... dont laugh :biggrin:
drexchan
2,908
100
Bukit Jalil
drexchan.fotopic.net
Why would it affect the exhaust while you are fiddling around with the vacuum hoses?
No lar..
nitrus
2,895
35
1,648
i c i c .. no la juz wanted to double confirm (although i also didn't believe it) .. from a claim from a friend .. tnx drex!
veilsideboyz
1,616
17
I install my oil catch tank few month ago... today i see under my car... i saw the a rubber hose ( unplug) from the oil catch tank... is it normal ??
Bump: I install my oil catch tank few month ago... today i see under my car... i saw the a rubber hose ( unplug) from the oil catch tank... is it normal ??
bugbear1986
156
drex chan... i need ya help here..
is it d same as urs for my wira carbie to install d OCT..
coz kinda confused wif wat d foreman said.. i edi got d OCT installed at the right side of the rocker arm cover...
so what bout engine breather? d small mushroom filter, they say carbie cars dun need this, or only for decoration purpose nia..... so any advice from you?
bugbear1986
156
On the PCV hose. The PCV valve is a hexagonal part, which is located at the opposite side in comparison to the EFi engines.
so u mean EFI is suppose to install OCT at left side, meanwhile carbie is at the right side.. :rolleyes:
---------- Post added at 10:33 PM ---------- Previous post was at 10:28 PM ----------
is this correct? OCT at left side in the pictures... then the right hand side of the hose is for engine breather..
drexchan
2,908
100
Bukit Jalil
Yes you are right.
Master[QQ]
41
Bro, disconnect the hose to the intake hose, seal the nipple, and install a small breather on the hose. Wira 1.6XLI auto can do it also?
bugbear1986
156
will it affect the durability of engine ..
bcoz my case is, the foreman says the engine will bleed~ oil leaking out from gasket, seals.. (aka 七孔流血).. bcoz the air inside engine room.. got no where to go/release...
We’ve all been to one of those car stunt shows that seem to consist of the staple diet of cars driving on two wheels, motorcycle jumps and of course, monster trucks pounding shells of cars into wrangled metal.
Well at least we thought that was the gist of it. Trust the Italians though to inject a shot of crazy and take things to the next level. Here we have Franco Medici taking a race-prepped semi truck on...
