perodua myvi
chinesepunk123
134
hie guys, need help badly. after changing my rims 16" with 205/45 tires, my fc have increased dramatically.
previously on stock rims n tires, full tank wud go 380km. now its just a measly 280km for a full tank.
just serviced my car last week (normal service). but the tires im using are 3 diff tires. front tires are same, back tires diff. my fren said dat was the problem causing the FC to rise.
so isit the weight of the rim plus the diff tires thats causing this? or my alignment? cos my alignment is abit off.
many thx ahead
keithmin
95
wow, 16" rims tyres cost a bomb...its totally not worth changing myvi rims to 16"...wat rims u bought ? made from where ?
frank118
435
24
You have to expect higher FC bro...larger tires rob you off in low gearing so you would have to step a bit harder...but the consolation is better handling lor...and looks good...
ninicoco20
177
may i know which ecu is better for myvi??unichip version q or e-manage??
FYI, Emanage / Unichip is not a ECU
its a piggy back
---------- Post added at 01:17 PM ---------- Previous post was at 01:16 PM ----------
Wah! ECU upgrade...what did you mod already??? BOT??
no need BOT can also change ECU or to add piggyback
---------- Post added at 01:19 PM ---------- Previous post was at 01:17 PM ----------
many thx ahead
yes, it will increase the FC
i am on 17inch shoe, but the FC is not as bad as your car
my FC only increase about 30km for full tank only
different tyre wont affect much on the FC brother, same goes to the alignment too
btw, your previous FC and current FC is it use at the same way/route???
if yes, try reset your ecu
---------- Post added at 01:21 PM ---------- Previous post was at 01:19 PM ----------
16inch tyre cost a bomb???
i dont think so bro
for me i am still affordable
its up to your budget also la
some more bigger shoe look nicer for me
mick87
576
112
wanna ask wat engine oil brands/type did u use for myvi?? recommended brand..
Hello. I,ve just installed a Zerone fully adjustable absorber on my car. It is currently on a quite stiff setup but i notice when i turn left then right, the car seems to sway as if the rear tire is turning as well ( like having a 4ws steering system). Im scared it'll oversteer. I dont remember having this kind of feelings with my Tein last time. The Tein gives me confidence & i can whack corner with no fear.
Or maybe the settings is not right with my Zerone? Anyone knows where i can tune...
