Thanks to KL Turbo One!!
AlucarD
1,079
115
5,163
Probably not much gain at that rev range for the TD04 15G unless you plan to rev till 8k rpm?! Anyway, I did not see the AFR of your dyno is it rich over 6k rpm
If you can do dataloging and a knock reading try and please try with caution to play with the ignition setting there might be a few horses to be gained there. Good luck & keep us posted
raja_emeperor
741
28
wah!your hp is much higher than my gsr with tdo5.
hmmm...kenneth gimme you contact number,need to have chat with u la.
Ozon
295
raja,
Ozon,
Ur from KL? there are many paces in KL for dyno tuning, however due to the limited market in penang, the charges for dyno rental with AFR in my place in penang:
First hour RM 250
Subsequent hour RM 100
i still consider these charges OK- laar...
TQ.......kennethfong
normality78
3,052
23
5,138
JB
care to disclose roughly how much u spent to service the turbo?
normality78
3,052
23
5,138
JB
got bigger pic of the dyno graph? i cant see. whahaha. my eye sight is damn bad
raja_emeperor
741
28
share la your mods bro, im really envy with your engine now.ekekeke!!!
pls answer my q,if not,im afraid i cant sleep tonite.huyo!! damn kaw la your engine.
what is your:
-air flow?
-injectors?
-throttle body?
-spark plug?
-fuel regulator psi?
-exhaust piping diameter?
thank kenneth for sharing.ehehehe!!
kennethfong
506
hi,
just went to fine tune as of 5pm just now, police didn't come so managed to finish the tuning, however i wanna cry already, my clutch can't catch up, i'm using 8.5 inch flywheel and clutch plate so clutch slip after 5K RPM damn sad....
i asked the dyno shop guy, he told me twin plate clutch at least RM 3 to 4 K wah lao erh!! y so expensive??? i dun wan single plate coz it's heavy like hell.....
anyway here's the latest dyno, RUN 1 is the last run that i posted, RUN 2 is today's run, managed to hit 270.3 HP at 6k rpm, and RUN 2 Torque is at 344.3 Nm at 4.5K, after RUN 2 however, my clutch is slipping already thus affected RUN 3 and RUN 4 figures....
kennethfong
506
normality,
sorry lerh, ZTH limited the file size, so i gotta downsize the pics which affects the quality....
raja, serenum,
- no air flow sensor, using megasquirt MAP sensor, to me air flow sensor is a big restriction to air flow....
- injectors GSR 390 cc
- throttle body original GSR izzit 60mm or 58mm??
- spark plug eerh can't really recall but i think i use expensive spark plugs should be Iridium 7
- i set my FSE at 38 during running i think...
- exhaust piping, ori mini GSR downpipe, 2.5 inch all the way including flexi pipe, then S Flow muffler 2.2 inch...
lypan,
atc = at the crank
atw = at the wheel
raja_emeperor
741
28
wtf?390 injector and std t/b??? wah! now i damn curious la.hmmm.....with all mods to my engine also i cant reach 250 hp mark! huhuhuh!!! really need to start from scratch back la. megasquirt where are you? here i come to grab u! ekekeke!!!
i missed my tdo4 la..less lag compared to td05. have to start a new project for my car rite now.starting to downgrade back my evo injectors,evo t/b,air flow and turbine.then i will install megasquirt.i start everything from that point. cheers! bro.
u bring a new idea of engine modification for me. :)
LyPaN
161
yehaa...
how much for the turbo servis + upgrade??
thanks kennethfong..i can see ur smiling face
even in the toilet room...hehhehe
ftzone
full throttle zone
5,339
141
Penang, Prai
www.ftzoneracing.com
hi kennethfong,
your power seems very impressive. however, each dyno machine will have different readouts depending on the calibration & the way to obtain readings.
i.e letting go the throttle w/o depressing the clutch on the rollers will have different reading on the dyno.
IMHO, northern garage dyno reading is on the high side. i got feedback from a stock gsr with safc can reach 250hp on wheels which i don't think is possible.
perhaps you can try out on a different dyno machine to compare. good luck with your tuning. :)
Black Wira, recently put on a Promote I front bumper. I removed the old sideskirts (ala GTi design) cos i had to take out my front fenders, and now without sideskirts my car looks kinda weird.
Any suggestions on what to replace them with?
If any members have pictures of the sideskirts, that would be even better! :regular_smile:
