Turbine Doubts
ken12292703
Drives a shopping cart...
1,542
5,138
SoMeWhErE
Hi brothers and sisters,
I have a very general question to ask, hope i can learn for you all sii fuus.
If an engine with a stock turbine with no boost controller can boost up to 0.6bar; then, a bigger turbine takes over and it only boost 0.4 bar.
Why is it like this? :X-:
Is it the bigger turbine would be heavier that exhuast gasses would escape through drain pipe rather than turning it? Please compare. :confused_smile:
Thank you so much in advance. :_:
acbc
4,615
KD
Remember to throw away the boost limiter... I threw mine away n boost went up to 0.9 bar.
jinkl
4,624
376
3,183
first let us know wht engine n wht turbo
new turbo n old turbo
there are few reasons
1st ur actuator is already weak
then check ur actuator flap could have hairline cracks
check ur boost cut selenoid
could also be that ur new turbo has an actuator to open up at 0.4
ken12292703
1,542
5,138
SoMeWhErE
Hi bro, previously was boosting at 0.9bar with a Manual Boost Controller. Then i took out the controller hoping to boost at standard pressure. See See~ Aiks~ 0.4BAR~ :confused_smile:
ken12292703
1,542
5,138
SoMeWhErE
Hi bro,
Okay, the engine is B8T 180
As i know the stock turbine is VJ20
Now VF10 turbine
Actuator opens at 0.4bar :confused_smile: how do i check this?
Thank you so much. :_:
acbc
4,615
KD
If confirm actuator kaput, time for a wastegate... hehehe...
ken12292703
1,542
5,138
SoMeWhErE
Wow, hahaha~
How much would it cost to chuck in a wastegate?
Erm, the thing is that i don't really know kaput or not. :confused_smile:
Please give some hints sii fuu~
acbc
4,615
KD
Well, if original Tial 38mm, should be around RM 900++.
If those Thai-made clones, RM 400++.
I'm using StreetGate-38mm, made in PRC. So far, ok. Spare parts same as Tial. Cost? RM 600.
Anyway, since u already have a larger turbo, why not do a 'banana' manifold also n chuck the wastegate on it.
ken12292703
1,542
5,138
SoMeWhErE
Thanks bro! :_: I'll put it on my upgrade list liao.
Can the original actuator be serviced? :confused_smile:
Thank you thank you.
jambunk86
570
20
Kajang
ken!...
wah, another b8 pilot...im using the thai wastegate...once broken the diapharm...after tuka, ok...hope help u a bit...btw im using b8t too...vj23 original...hehe...
ken12292703
1,542
5,138
SoMeWhErE
ken!...
Wow JAM!
Nice to meet you. Thank you so much for the comments. :_:
It seems like B8 is getting unpopular soon compared to others. :confused_smile:
Boosting pressure at? :mouth_closed: Wuuhuuuu.
i recently serviced my car last two months ago because the gasket is broken..
now i have changed the oil gasket, timing belt, spark plug, u name it..
the black oil still leaks as though its' like a girl who's having period problem.. :(
any advice? the fuel consumption is like ..err not so good la.. rm 10 for 70 km .. last time used to be 110 km..with some rembat here and there. :P
i;m driving a satria 1.3 carbie, is there any ideas?
