adj cam pulleys function as?
WestCoast
194
what can we do with adjustable cam pulleys witout hi cam?
adj cam pulleys without hi cam is useless or worth to spend on it?
raja_emeperor
741
28
hmmm....sorry im not rocket science to explain this, but it is like u want to adv and lagging abit your exhaust port or intake. bout performance wise it can make your engine to rev higher.
WestCoast
194
hmm...okay..does explain a bit..wat i act wana knw is does it free out extra hp?
heard it is much more effective on a dohc engine..since my ride is a 4g93 so might wana install arospeed cam pulleys on my ride
raja_emeperor
741
28
it might help increase your hp abit,should be not more than 10hp of power increase on higher rev.
yup..it help alot for doch engine.so go for it,you will notice the diff bro.
jinkl
4,624
376
3,183
u can adjust them if u gt a experience mech
u give it better low rpms , u will sacrifice high rpms
u give high , u dnt get the low
WestCoast
194
act i started this thread cause the main problem tat im worried about is wat jinkl just mentioned..jz wana confirm whether its true or not..since its like tat wihtout hi cam so no point to install it..instead of spending on adj cam pulleys maybe i'll go for fuel regulator or spend smart on sumthn else
raja_emeperor
741
28
its all depend on what do you want from your car, is it better low rev or higher rev and this will sacrifice streetability, or better not to kacau anything and leave it stock.even if u put hi cam also u might facing idling problem.
so if ure afraid of all this,dont play engine mods,makeup only drive slowly and dont forget to put larger exhaust so that ppl will scared to kacau you. :)
WestCoast
194
hehe..yala hor
but dowan touch tat valve train la can mod other ma.like fueling n air intake ma
raja_emeperor
741
28
u can start with open pod air filter, i dont think it is wise enough to put fuel regulator, this will only wasting your petrol, better tune your air fuel ratio.use SAFC as a start.
happy motoring. :)
WestCoast
194
okok thx for ur advise mayb will opt for e man lah cz nowadays e man so cheap d
WestCoast
194
open pod open d ma cai n airbox oso got d la i mention my mods a lot time on zth thread d lor! open gf pot pot havent lah..jaja
piping all oso done d ma sumore close ratio gb ler very the steady i tell u..^^
basic mod done so hiao hiao wana do adjustable cam pulley lor since no diff then nvm dowan do lor..go comment my new thread at car mod im opting for aftermarker intake manifold for 4g93 damn nice 1.. :)
Boink Boink
191
3,018
Bro,
Have you checked out "How Stuff Works" ? There is a specific write up that gives great pictures and stuff.
That said, Laymans terms, adjusting cam timing is equal to adjusting the rate at which you breath in and out.
If your body is at rest, the breathing rate (Cam Timing) will be very much different from when you are running after Ben Johnson in the 100m sprint.
Hence get the two mixed up, like running after Ben Johnson with a breathing rate set to rest.... well... you get the picture now.
WestCoast
194
not very understand lah..heh
whr the website to see more details?
The Marketplace Top Posts
There's a new UHP candidate from Continental Tyre lately, and it's not just another Sport Contact sibling either. Yes you've heard, It's the new MC6. Short for Max Contact, The new MC series will not just replace older MC5, it takes on a new role in the world of Ultra High...
