UnderTree Mechanic - DIY Videos
lsm1991
1,469
185
After an accident one is good.
Some knows but the leverage is not there. If 3 years never remove lug nuts before, its quite hard lolol
i have watched ppl b4. Mau jack, unsure mana jacking point... then the fella jacked the car up and tried to loosen the bolts when the wheel in in the air, futile attempt as the whole wheel started turning also dont know why he insisted on trying to insert the centre cap onto the spare space saver wheel (also a futile attempt) when he was done
  • Haha
Reactions: Izso
leinnz
333
57
3,028
Memang pun. He has no shame.
Neither do I.
I have a suggestion, we need video on:
How to jump start a car (and how NOT TO jump start a car)
How to change a spare
What to do after an accident in Malaysia ( DO NOT LET TOW CAR TOUTS TOW YOUR CAR, call your insurance and send it back to manufacturer)
jump start an electric car, hybrid car or new tech car
mosesmk
165
32
Selangor
I stopped buying tools from Mr DIY after one of my open ended wrenches deformed and became a size bigger after I tried to remove a nut. Luckily it didn't strip the nut.
I just use their ratchet. seems decent quality. socket i use one buy from normal hardware. my mechanic always quote "better the tools broken then the nut".
Reactions: Izso
eh jom. Let's do this video. I help you video it - and considering how much lighter you are compared to me, you can demo how to remove over tightened lug nights.
Uh.... you find someone to loan him one and he'll probably do it. HAHAHAHA
mosesmk
165
32
Selangor
good stuff guys, maybe you can consider offering your mechanic services here too
my current mechanic now already upgrade to a proper workshop from under tree. one old uncle mechanic just pass away few months ago. he also under the tree mechanic with proper knowledge and friendly.
Reactions: minibeany and Tom
Last week, my daughter informed me, she was at stall, saw a man trying to remove a flat tyre for his female friend using the tools from the car. He tried and tried, then was about to give up. My daughter got to her car and took out steel pipe, walk over to them ask them try. The man smile, ah I need this, but the female looked stumped. Then the man attached the pipe as an extension and remove the lug nut. Then only the female friend say, oh.....hahhahaha
Reactions: Izso
stupidcar
5,000 RPM
5,567
850
Yeap, i showed this in the X70 video.
New followup video is up
I wonder how much difference will it be if both cars are using the same tires.
Initial bite of ori brakes is better but braking power very much remain the same after the initial bite. For aftermarket pad ( i used Trestor too ) very2, very2 inexperienced driver will say brake tak makan. This is much more evident for city cars.
What i love abt Trestor pads is that the hotter it gets, the better it perform. Of course thats until one exceed the limit which is very hard to do on a daily car.
I am curious as to why some brand of pads comes with some sort of backing plate material (fells like some sort of foam/silicone) but some dont.
What model Trestor are you using? I am using Trestor Blue Advantage, the older model. New model I think they drop the blue now called Trestor Advantage. Previous 3 sets of Bendix MK, MK Gold and MK Titanium. Trestor Advantage to me very much better since bite from cold. Bendix I need to warm them up first......lol
This simple circuit makes it posible to monitor the charging process to a higher level.
Final adjustsments are simple and the only thing needed is a digital voltmeter for the necessary accuracy.
Connect an input voltage of 12.65 volt between the positive and negative poles and adjust the 10K trimmer potentiometer until Led 10 lights up. Lower the voltage and in sequence all other Led's will light up. Check that Led 1...
