Show us your lancer/evo pics!
sweelt
Nov 6, 2016
2,306
248
Yes, just keep cranking but if jump started with enough juice then it will on. Based on what I read seems to point to crank sensor.
my x-gear got one time it cranks but no start occasionally.
At last check due to battery weak.
sweelt
Nov 6, 2016
2,306
248
Strong cranking
Your problem during hot start, except you jump start it. If drive back home don do anything, cold early morning can start without any fear ?
Heat soak can affect so many things. Weird becos evo got hood vent.
Yes car always can start the first time before driving. After driving then cannot restart again, maybe until a long time.
sweelt
Nov 6, 2016
2,306
248
I assumed even hot engine bay, battery voltage still good ?. If yes can rule out voltage leak.
And check as @Izso mention wiring connection, recently installed sensor.
Heat soak issue and jump start macam diff scenario. My noob observation btw.
marsha1l_v6
666
130
543
i had this issue before..similar to say the least
i was WOT my car and suddenly engine stall. long story short: it was ballast resistor failure. I dont know how ,as its just a resistor.
engine can start and running during cold start. since u change injector, probably can take a look.
took out one of the cylinder plug to see if theres anything wrong with ignition/coil, spark is there.
monitoring the afr gauge for any fault in fuel system, check out everything ok.
starter crank strong, i keep on crank + gas till battery kaput.
me and mechanic called two different tuner, both mention injector resistor ballast faulty. According to them, those ballast commonly fail during dyno tune. Ive send the car for dyno twice before, and fail while im on the road. Since then, i have spare ballast standby. :nurse:
Reactions: 6UE5t
This reminds me of an old case with my video player, when hot it shuts down. I think you got something here. My case with the video is one of the capacitor break connection when hot, and joins back when cool, so could be similar case like this.......lol
Hmm ok thx for the info, I will discuss with my mechanic.
hope it helps and you can enjoy your modded evo asap. Let us know your latest gain after those mod.:driver::driver:
My mechanic said it's solved already, will pick up the car this afternoon. He said it's cam sensor already weak. Maybe magnified by changing cams too. He has just done on road tune as well. Maybe next Saturday dyno tune in Sunway.
pls do yourself a huge favor and have your car dyno tuned on a mainline dyno not a dynodynamics machine.
How does changing the cams magnify it? It's just a positional sensor.
Not exactly sure to be honest, it's just my own thoughts. But it's confirmed the cam sensor issue, so he changed that. He also added extra grounding to help.
My mechanic regular dyno shop is mainline but it's broken now for a few months! So need to look at other options.
Reactions: Izso
parakey
1,367
226
I read that cam sensor issues occur after replacing the camshafts. Often it's due to shoddy work. Oil leaks into where the sensor is or dirt/metal shavings interfere with the sensor's readings.
Sorry i started this thread here because I couldn't find any categories for accessories. And I think, this can be considered a light modification?
I just want to ask anyone to share their experience if they have ever used a H4 single beam HID system.
I am planning to retrofit a HID system into my AE111. Yes they are using projector assembly. But I have spent some time researching and I could come up with a glare shield. It wouldn't harm oncoming driver's eyes and is very pleasing...
