KHNG940413
668
56
johor bahru
If properly hooked, it couldnt have opened on it's own. Then again, it's a Mivec hood and I believe you need to mod the hook a bit. Rather than look at it as bad luck, you should think of it as fortunate; you could have been going much faster.
I had check the hood everytime before I drive. Juz a small push down and tarik to check will it pop up
parakey
1,367
226
Does this mean you havent figured why it would pop up on it's own? Please check the cable release and the latch mounted on the hood itself. If possible, please share some pics
KHNG940413
668
56
johor bahru
Yes,now still cannot figure out why the hood is open when driving. My friend suspect is when I go over a hump or pothole causing it to loose and pop up.
For now it don't have any issue. I will switch to a stock wira bonet & bumper since the fiber bonet is cracking.
And the Old mivec Bumper I will sell it to cover up my expenses. Hahahahaha
minibeany
598
102
543
Get Evo3 bonet :-)
parakey
1,367
226
Ori the price is like skyhigh. A used mivec bonet also cost around RM400+
Standard can already larr....Hahahahaha
Engine kuat can already
There's fibre copy which can be had for quite cheap but I cant recommend fibre. Either way, you need a new grille
hi guys,
For the intro, my sister in law have a Proton Savvy AMT and currently some part of the gearbox is not working well and after asking for the replacement parts @Proton service it costs around RM9k. So I'm thinking of suggesting her to just swap the engine into other alternative engine since the current engine maintainability is quite high.
So the question here, what are the available engines that can fit into Proton Savvy? Legally endorse of course. At the moment thinking...
