Damn...Is really frightening. Is like those movie scene the bonet suddenly pop up and you can't see the road and you still need to steering your car not to crush is really scary.wow... that's dangerous!
I had check the hood everytime before I drive. Juz a small push down and tarik to check will it pop upIf properly hooked, it couldnt have opened on it's own. Then again, it's a Mivec hood and I believe you need to mod the hook a bit. Rather than look at it as bad luck, you should think of it as fortunate; you could have been going much faster.
Apparently the hood is a little big so when the hood pop it bend back causing this happenView attachment 576886
Dont appear badly bent. Did you bash it back in?
This is a fiber bonet.thats either a fiber bonnet.... or the wrp over it is torn?
Does this mean you havent figured why it would pop up on it's own? Please check the cable release and the latch mounted on the hood itself. If possible, please share some picsI had check the hood everytime before I drive. Juz a small push down and tarik to check will it pop up
fa as i can see..This is a fiber bonet.
Yes,now still cannot figure out why the hood is open when driving. My friend suspect is when I go over a hump or pothole causing it to loose and pop up.Does this mean you havent figured why it would pop up on it's own? Please check the cable release
Get Evo3 bonet :-)Yes,now still cannot figure out why the hood is open when driving. My friend suspect is when I go over a hump or pothole causing it to loose and pop up.
For now it don't have any issue. I will switch to a stock wira bonet & bumper since the fiber bonet is cracking.
And the Old mivec Bumper I will sell it to cover up my expenses. Hahahahaha
Ori the price is like skyhigh. A used mivec bonet also cost around RM400+Get Evo3 bonet :-)
There's fibre copy which can be had for quite cheap but I cant recommend fibre. Either way, you need a new grilleOri the price is like skyhigh. A used mivec bonet also cost around RM400+
Standard can already larr....Hahahahaha
Engine kuat can already
Tomorrow I will take a picture. My latch is single only not double.Hey, does your current hood latch look like this
Hopefully not as filmsy looking as the one in the pic. Check yours to see if it's looseTomorrow I will take a picture. My latch is single only not double.
