Discuss About Your Car...
jackng78
21
503
maybe by default is KL, anyway I'm from Butterworth. Again, do you know where got formen know how to dismantle EMO sensor(that sensor on start switch area)?
jackng78
21
503
wireman checked n found te fuel pump n engine no electric supply, not sure ECU cut off or not? is there anyway to unlock?
sweelt
Nov 6, 2016
2,306
248
bro, i duno where to point correct workshop instead please go sc. Guessing here and there will give you more headache and $$.
jackng78
21
503
bypas the emo, still cant start n formen found engine pressure not enough to start... is change engine is needed? cause formen ask to change engine.... got better advise?
parakey
1,367
226
Bro, I hate to say this so please excuse me. How did it go from an electrical issue to an engine one?
Your initial problem was engine cannot start. Large power drain and ecu/immobilizer resets. Then later it was fuel pump and ecu not receiving current. How did it suddenly become 'engine pressure not enough to start'
I mean no disrespect to your mechanic but from the flow of events, I currently have little to no confidence in him.
Later after change engine still got same issue, then what? Will he then suggest change car?
Please take the car and go to another mechanic for a second opinion.
lsm1991
1,469
185
i agree with parakey.... get a 2nd opinion, frankly nothing makes much sense....
if u seriously really want to get in depth into troubleshooting, you have to explain exactly whats happening....
Your mechanic has to know what's he doing and thus far, and based on your descriptions so far, i have a suspicion he does not know how to troubleshoot, only transplant. What happens if a similar issue pops up? start replacing more bits? that's plain ridiculous
engine pressure... whats that got to do with an engine starting.... even with 0 oil pressure, your car will start. It won't live long, but it will start.
koshin
53
17
Vietnam
waaaa when a foreman man tell you change engine you better take ur car and lari kuat kuat liao. First time i heard this type of sorhai comment asking to tukar engine. you better change foreman la. If you keep using him you sure hailat wan. Sorry I tak belajar banyak like the other so kenot discuss technikal term but i can tell you this panchat mech no good la. Bring to service center la
sweelt
Nov 6, 2016
2,306
248
Bro, this is your regular foreman Or u just walk in and state ur problem?
No such thing as simply say change engine. Pls go SC or get 2nd opinion. Maybe ur car is rip apart just pay the foreman to fix it back and get ur ass to other workshop.
I worry if ur car stay in this workshop, the cost will be same as 2 engine eventually.
What engine pressure? You mean the piston compression not enough pressure? If that is the case should still be able to start
This reminds me of one case. Car owner car jerking, send to mechanic, change plugs, no difference, change spark cable, no difference, change distributor, no difference, then don't know what else change here and there, finally his friend introduce him to my mechanic. My mechanic check then listen to his story say almost everything change still like that. So happen I was driving same model of this car, so he called me up, can bring my car to use some parts. Drove over he remove the electronic ignition transfer over and issue settled. Order a new unit fitted in and solved, but at the other mechanic he paid for many things blindly already......lol:rofl:
lsm1991
1,469
185
alot of mechanics nowadays macam tu... main bantai tukar je.... xtau troubleshoot.
Porsche has announced that the drop-dead gorgeous 918 Hybrid shown at last year’s Geneva Motor Show will be fulfilling the wet dreams of petrol heads by plugging into reality and hopefully, a power socket near you, soon. A Porsche with 500hp and an additional 218hp from the twin electric motors, it’s definitely going to be on our Christmas wish list...
