Hissing Sound
loose_end
3,649
197
Malaysia
Dear All,
Engine : 4G15, 3 speed auto
Problem : Hissing sound
There will be a hissing sound for about 30 second from time to time ( Only when the air con is on ). The hissing sound does cause a drag (negative load) in power. Usually only happens about 80km/h and above. Air con still cold.
What's your thought ?
Dear All,
Probably just the air con refrigerant passing through the system, at the expansion valve before the cooling coil. When air con compressor is on there will be a load on the engine....:driver:
RENESIS VIII
7,063
950
Ipoh
Sometimes I can hear such a sound too. Now your explanation revealed what it is. I can guess it has something to do with air cond but not sure which part of the system or what caused it.
RENESIS VIII
7,063
950
Ipoh
Speaking of air cond, the whole air cond system for the Myvi I have at home is busted. Brought to shop today, need RM1700 to fix it. Need change compressor, change condenser, clean all those piping/coil. The shop say now change to a brand called SWJ, if use original Denso, need over RM2k.
Means compressor kaput and got debris is the system, need to change everything.....:bawling:
RENESIS VIII
7,063
950
Ipoh
hoho am hoping its just a leak in the evaporator.... the compressor i installed last year was almost new!! should bawak n get it checked out soon.
What are the symptoms and problems that you are facing? No cold air?
The one I had faced in Myvi would be a loud sound when the air cond is switched on. Some kind of whining sound like supercharger sound, lol. It has been going on like that for almost 3 years already until recently cold air stopped coming out.
lsm1991
1,469
185
mine... its like this, installed the ac last year, all fine, then used it for maybe 1 month? then never used it again till earlier this month when i found it blew very little cool air (basically air is only 'slightly' cool). One thing i did notice was it did hiss every once in a while, and hissed more loudly when i reved the car up..... didnt realise that wasnt normal (my old lmst also hissed alot, but that was fine)
Hey guys,
I'm in the midst of either buying a new BMW320d M-Sports @ BMW525 M-Sports (used) @ Fairlady 350z (used)
Can anyone share some opinion which car would you choose and why?
Reason for me to consider 320d M-Sport was because:
1- Fuel consumption vs high torque
2- Sporty
3- Bimmer
4- iDrive
Reason for me to consider 525i M-Sport was because:
1- Beautiful 6 potter
2- iDrive
3- My dream car
Reason for me to consider 350Z was because:
1- I want to try driving a...
