Weird substance inside radiator
RENESIS VIII
7,063
950
Ipoh
AVS Aluminium radiator...quite old already though.. i think more than 6 years in the car.
If it is aluminium, then how can it rust. :confused:
Especially taking and submitting parking ticket, don't use window damn susah loh.......:thefinger:
But now, the problem appears on passenger side front window. Can't argue with that. Also, the Myvi I have at home also got window problem. Very difficult to wind up, easily get jammed. 3 windows affected. Only driver side okay. :banghead:
Check see what is wrong. Sometimes misalignment, sometimes rubber and glass tight, sometimes cable, or motor no strength dy. So got to check what is wrong and tackle accordingly.....:driver:
RENESIS VIII
7,063
950
Ipoh
It has been like that for quite some time already. Just that family and my younger bro din't bother to get it checked. They just say, leave it and don't wind down the windows. Plus, now my younger bro is at PJ, the car is left at Ipoh. Become like my 2nd car already. :biggrin:
It has been a week already since the thermostat fix for my car. So far, so good. Temperature won't even go over 50% no matter what.
Bremboy71
15
1,503
Unmineralized water see if you can find it or change your coolant. We found some issues with certain coolants that they say what they want on the label, Use a good brand to avoid any complications.
RENESIS VIII
7,063
950
Ipoh
I'm using this Toyota coolant now. Should be reliable.
mADmAN
1,840
547
god knows... but previously was using tap water... for about 5 years.. pure tap water only.. no coolant
RENESIS VIII
7,063
950
Ipoh
Maybe the material inside the radiator? I don't know... Or the water pump? Must be something within the water circulation system. :hmmmm:
shiroitenshi
3,676
170
ehh the gunk is the thermostat itself!?!?
thats weird!
could be something else. but if it's not oil, then it's the wax thermostatic element inside the car thermostat (I think all car uses this type, but maybe got some exceptions). That's why if it feels like wax, it's from the thermostat internals, probably leaked due to age and corrosion. I don't think engine temps run hot enough to melt thermostats.
Otherwise, its usually from the sealant mechanics apply when installing waterpump. I think the sealant would be recognisable if it was sealant.
The alternatives are... someone put something in the coolant?
ken yeang
6,617
1,327
Just to share with all.....
Toyota coolants are sold at either spare part shop, or Toyota Service Centre. They look the same.
However, the prices differ a lot. Dont believe, go ask and compare the prices from the sparepart shop and ask at Toyota SS.
So, be careful not to buy the fake coolant, guys.
The boss of my usual spare part shop also said "...item such as coolant, engine oil are popularly imitated".
RENESIS VIII
7,063
950
Ipoh
Perhaps the weird substance that I found on my radiator water came from the thermostat.
What is the price for those found in Toyota Service Centre?
hi all zth menbers
can some 1 tell me that izzit illegal who keep a golf stick inside our car?
thinking to keep 1 for self defence.
anyway can share your idea or experience.
tq
