Where to custom piston and con rods
speed2horizon
2,798
334
1,683
Combine metal gasket lor. Each metal gasket consist of multiple layers. Top and bottom are seal gaskets, the thick layers are space gaskets. The super thin one is compression gasket.
Remove the top and bottom layer of one gasket, slit in the remaining gaskets into another gaskets.
There u go. A custom thickness gasket.
yewly1990
156
28
But actually how do I know how thick I should go?
speed2horizon
2,798
334
1,683
I do remember uploading an equation here for metal gasket thickness and compression ratio. But i forgot which century ago... lolx.
KeeSeong
78
508
Mine also BOT on crz... stock internal running 0.7 bar...also feel wanna change piston scare over boosting when up genting.. hehe always look at the water n oil temp gauge.. scare up.. hahaha
But bros said no problem wif low boost i reli hope no problem.. haha
is it true tht thick plug cables would create EMI(if i'm not mistaken) when spark which will interfere with our car's electronics component?
hope sifus can give some guides n experience cause i'm thinking to change it to a thicker plug cable...
thanks
