I had a wira 1.5 auto fuel injection when ever I climb up hill I press down the throttle the engine go on. Can anyone pls advise me what happen do I need to clean up the throttle sensor or ecu problem?
When full throttle do you get any other side effect like choking or stuttering? Possibly one of the sensors need checking. Also which Wira is yours? VDO or MMC?
have to check with computer lh bro.
happen to my friend wira before but his is 1.6 model.
in his case its the knock sensor which has its connection not good.
nothing isnabnormalnabt the engine running.
hi i have issue also on check engine light. the diagnose appears “isc servo valve / iac v. pos. s/circuit” . the mechanic said i need to change the TB around 380rm? do i need to change? because i read mostly issue on proton wira was sensor need to replace. thanks who will answer.
currently my car have some dent and rust..so i do all the bodywork,knocking and simen all by myself..but the problem now..i dun hv enuff money to paint my car
so is there anything i can spray?not the normal can..cos when i wanna paint..all musr rub again..i need something to spray just for a meanwhile by tyhe time i get enuff money
is there anything like can type undercoat for automotive use?
