Persona Owners Thread
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
I think is to make the mounting flex less right?
:o Purpose? Sound dampening?
It's the DIY method of making a solid engine mount. If you've ever seen those PU solid engine mounts they don't allow the engine to move around as much theoretically transferring all the power directly to the drivetrain. It's the 'softer' alternative to the solid steel engine mount since PU allows for some very minor flexing.
jackocc123
Apr 5, 2012
7
any one here using adjustable ??
Just want to ask what Spring rate suite for persona , for stable when corner+ comfort.
A. Front 6K + Rear 4K
B. Front 4K + Rear 4K
C. Others
DIY for that then will need stronger materials other then window sealants....:biggrin:
I`m a mechanic myself. but this Renault Kangoo is givin me headache! Cold start,ok! But when it has done 5 to 10km, it will suddenly dies off! I had top-overhaul the engine, T.belt replaced, coil replaced,CPU re-set,battery replaced. The temp. gauge shows fine at optimum. At times it will jerks when accelerate. An original fuel pump was also placed. pls help.
