Persona Owners Thread
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
I think is to make the mounting flex less right?
:o Purpose? Sound dampening?
It's the DIY method of making a solid engine mount. If you've ever seen those PU solid engine mounts they don't allow the engine to move around as much theoretically transferring all the power directly to the drivetrain. It's the 'softer' alternative to the solid steel engine mount since PU allows for some very minor flexing.
jackocc123
Apr 5, 2012
7
any one here using adjustable ??
Just want to ask what Spring rate suite for persona , for stable when corner+ comfort.
A. Front 6K + Rear 4K
B. Front 4K + Rear 4K
C. Others
DIY for that then will need stronger materials other then window sealants....:biggrin:
engine is pinging when the weather is hot, all smooth when it's not.
took the sparkplugs out and realized the mixtures are too lean
what can i do to overcome this? fuel regulator? pump? bigger injectors? just the simplest and cheapest way to do it.
