Any Difference Between SG and MY Satria Neo?
escksu
145
28
Singapore
I am just wondering since it comes from same manufacturing plant, by right should be the same right?
I am just curious. Cause heard that MY Satria Neo is superior compared to other countries, got more power, better quality. So I was like a little sad..... I paid so much for my Neo (bought a 2nd hand Neo for SGD 37K, thats around RM94K) and its not as good compared to MY one... :(
Veloc
3,234
991
Sabah
Don't worry you got a superior car. Because most exported proton models are superior especially on its safety rating and quality of parts. Malaysia does not give shit on safety (i mean it is not a legislated thing) of cars. Airbag is not mandatory. Design need not be pedestrian safe. Cars are allowed to have tin can like hardness and rigidity. These are all regulated in more advanced countries so I believe you got a good car.
YellowFlash
308
34
Jb
think export models have good QC before exporting whereas local ones doesnt have such stringent QC hence yours should rightfully be better...
escksu
145
28
Singapore
Talking about air bag..... I actually hate air bag cause it adds weight!! I am thinking of removing the airbags in the car.
cvkit17
2,884
1,354
The car is almost identical. And dude, seriously? Removing the air bags? How many kg are they? First of all, what is your weight and your height? Removing air bags would not give you extra 1 secs off the 0-100 time la. It is meant to save the lives of hot running bloods like you.
Dude escksu, you wanna save weight, remove the rear seats not the airbag. Empty the boot of the spare tyre and use temporary flat-o-fix type of canisters. Then switch to CF front seats, change to a CF hood and doors (forget about the fenders, same weight), strip out al bitumen soundproofing and takeout the carpeting, then finally switch to lightweight rims - conlanfirm your car will be lighter and nimbler.
lefties
28
11
1,503
penang
comparing those 2 won't get an different...it's totally same spec I believed....unless the car is for Euro or GCC market...the spec requirement is different......of course I'm talking about Proton car :biggrin:
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Yeah, just more accessories! Euro or GCC also from Malaysia factory ma.
Proton only has factories in Msia right?
DanzEterna
15,911
3,371
www.primeperdanaclub.com
must loose weight too...be as skinny as hell:rofl:
Veloc
3,234
991
Sabah
I don't know what you want. You want everything. We already told you that Sg model is better in terms or equipment and safety, then you said you want to remove the airbag. You want something superior but eventually you downgrade it???
cvkit17
2,884
1,354
Well actually...you paid RM94k for a Satria Neo from Singapore. I believe that doesn't include COE, does it? No matter how great the accessories in the SG Neo, it is overpriced if you compare to Neo in Malaysia, even if it is Neo R3. But first thing first i.e. do you have the permission to buy or drive a Malaysia registered car? (I assume that you are a Singaporean, or a PR). If no, there isn't really much you can do about it, is it? So just live with it and now that you have a Malaysian car, you can find performance parts or spare parts easier and cheaper in Malaysia. Good luck.
lefties
28
11
1,503
penang
yeah...proton only have plant in Malaysia lol....all proton export car was assembled in Malaysia plant also......
---------- Post added at 07:32 PM ---------- 6 hour anti-bump limit - Previous post was at 07:28 PM ----------
SG Neo should be about the same as MY ones, right? unless is meant for EU....
yeap....it's totally the same...same spec..... different price:biggrin:
hie!
I bought door trim wira 1.6 complete wit all 4 switch.
the driver side can control all 4 window..
mine is wira 1.3's which only can control the front window only and the switch is right in midle of the console gear.
so, how i want to do the wiring that can control all the window.
plan to install the from panel first as need to buy the motor for back window next month..
here is my switch...
