- Mar 15, 2006
- 1,501
- 349
- 1,683
My ratio is easy for every 1 liter of petrol my 2t is 2ml.
Now trying TC-W3 grade feel better compare to shell JASO-FC grade.
haha...dun get confuse wif my profile pictures....bro,
ur engine is 4AGE ist? n how much we need to pore inside te fuel tank..i means ratio to fuel ?
n which brand n model/code number mostly suit 4AGE, Tq very much:hmmmm:
ok, tqhaha...dun get confuse wif my profile pictures....
i test this wif my viva...
using the mobil 1 synthetic 2T.
i usually just pour about 30ml of 2T.viva tank is really small one...
usually fill up around 25litres of Petron ron95.
But TC-W3 and JASO just different certification body specification....:hmmmm:My ratio is easy for every 1 liter of petrol my 2t is 2ml.
Yes 10k till today.
This my condition service is check plug, check how much carbon in the intake by using amsoil power form to flush the intake surprise the exhaust coming out white smoke is less about 1/3 or less compare the last I do at 40k mileage.... now my engine is 107k mileage. All this time been continue mix 2t.... I think I miss less then 5 time without 2t in my petrol.
One thing is TC-W3 seems to be ash free, means burns clean, probably same as JASO FD grade....:hmmmm:Yes both are different but my butt feel better... mileage abt the same but power respond better... maybe this tcw3 maker is better...
yes maybe but i have check with a biker taiko he comment is yes less ash output but different tc-w3 brand will have different affect some will cause our piston surface very dry maybe for long time maybe cause piston surface crack..just maybe ...One thing is TC-W3 seems to be ash free, means burns clean, probably same as JASO FD grade....:hmmmm:
Some motor bike shop might have, TC-W is a oil grade like JASO-FC or JASO-FD grade...sifu,
where to buy tc-w3 ? n TC is te brand name ? tq
Im selling it as well as Amsoil product.Where to buy the amsoil foam?
Yup, more for outboard marine engine.....tcw-3 is marine grade 2t oil..
used for outboard 2stroke boat engine.....
got some brand like quicksilver and maxoil
they encourage to use TCW3, any TCW3, the cheaper the better it seems due to cost"Actually your not the first to send me that But thank you.
It is very focused on two stroke applications and not as a fuel mix as you know. We do not look to the 2stroke oil as a lubrication for our crank/cylinder/rings etc.
What we are discussing/testing/sharing has more to do with certain properties in the TCW-3 that make it a excellent fuel add to gasoline in a 4 stroke engine. Also our mix ratio is significantly lighter.
With that said....I do not see anything in the JASO FC spec that scares me adding it as a fuel add in a 4 stroke.
Thank you for participating and adding your thoughts/experimenting with us."
i think outboard engine got lower rev then a motorcycle, and its water cool so the condition is almost identical as in a carYes outboard marine engine most of of the time rev at higher rpm and for longer duration....
Next will compare a cheap grade and synthetic grade see which have better ratio price over performance...
