Adding 2T as petrol additives...
xbalance2002
1,501
349
1,683
if you guys remember this
[/COLOR]
i think outboard engine got lower rev then a motorcycle, and its water cool so the condition is almost identical as in a car
i remember last time when i was take a ferry ride to pulau perhentian island this ferry use 2 yamaha v6 300 series his rev meter was showing 6000 ~ 7000 rpm and he maintain this range...
after been using for 250km on tc-w3 grade notice it pull better then JASO FC and some time FC range about the same and some time even better...
csl
1,285
498
1,683
Malysia
remember, over dose will kill fuel pump. My car is on the 4th fuel pump. The last change was 4 months ago but that was accidentally over pour about 200-300ML. Semi dead after that tank of fuel finished. At long drive, the pump got heat up and malfunction. AFR at 9k rpm @ 12 suddenly cut by ECU and the rpm unable to go up to 6k where the AFR become 17 then 5k then 4k then slowly the car dead and need to wait for long time for the fuel pump to cool down before able to start the engine. Short distance no problem.
arturo
nooB
2,721
1,083
3,213
SateCelupLand
on yr rotary?
xbalance2002
1,501
349
1,683
After switching from 2t JASO FC to TC-W3 with the same ratio mix TC-W3 have better pulling power and mileage notice improve abit from JASO FC grade too...
xbalance2002
1,501
349
1,683
Today mostly highway.... test done with about 575km with 4 adult passanger with 330kg of weight extra... constant speed 140 to 150kmh... I think this tcw3 performance is better then jaso fc
xbalance2002
1,501
349
1,683
i dont have this issue only if my shell JASO FC ratio more then 70ml per full tank refuel only notice power drop and FC drop too
