4G92P N/A Or BOT
Jbdragster
10
Hey guys!!
Saya baru lagi dalam dunia modifikasi enjin ni..sy menggunakan enjin 1.6 sohc (4G92P) pada satria saya.
sy ingin menambah HP pada kereta sy patutkah sy BOT kan atau stick pada N/A
Mintak pandangan utk N/A nak masuk barang apa bagi cun + HP..
Mintak pandangan utk BOT nak masuk barang apa..
budget utk engine upgrade RM5000: :confused:confused:
ehdrian
I Don't Care!
3,310
280
1,683
i think yr budget isnt enough to make 180hp NA.
better BOT then.
Jbdragster
10
i noticed dat 180+ is too high n much HP..but i more prefer N/A...can easily go 200kmH should be ok...but what should i set in?any suggestions?
ehdrian
I Don't Care!
3,310
280
1,683
Jbdragster
10
owh...but if i wanted to stick on SOHC shoud i upgrade the cam , distributor , air intake , bigger throttle body , injectors or etc? ECU also change rite?
any recipe sifu?
btw thx for the link.. i look forward if i dont wat to use SOHC any more...:biggrin:
and how much its cost too...
huhu
ehdrian
I Don't Care!
3,310
280
1,683
Oh, am not familiar with sohc mods.
Let other sifus to help you.
xtremeleo
3,247
464
5,183
charging it will give u better torque and power,better fuel economy,and will be cheaper den forcing a 93 to churn out 200hp,iam just saying..
Jbdragster
10
Ok ehdrian..btw thx for ur other opinion..really apreciate it man...
:wavey:
---------- Post added at 08:05 PM ---------- 6 hour anti-bump limit - Previous post was at 08:03 PM ----------
Ohw...so how much will it cost to BOT my engine ?
Any parts list u have in mind instead ?
Heheh
g88
3,081
54
5,148
SOHC not meant for mod. Keep as NA. If want upgrade to DOHC
dking91
121
11
pekan
target hp kne kurang kn skit..rse nye plg power org buat 4g92p na 160hp...
kalo ikot idea sye
1- tukar sistem exzos
2-lighten flywheel(skim)
3-rebore(82mm/83mm)
4-high compression piston
5-bigger injector(240/270)
6-bigger tb(60mm)
7-head port&polish
8-tuning(rechip/remap/emanage)
sye pon pkai 4g92p tp xda mod byk sgt pon..bru overhaul, 82mm piston, flywheel skim sikit, skim head, exzos sistem..
dri auto tukar manual
kalo total kn sume duit yg abis, blh angkut halcut mivec doh sbnr nye..tp yg pntg kepuasan dan menimba ilmu :)
pendapat newbie yg bru join :)
Jbdragster
10
kalo ikot idea sye
3-rebore(82mm/83mm)
6-bigger tb(60mm)
7-head port&polish
saya ada buat list sikit..but xtau la padan ke x..antara barang saya nak masuk adalah :
1: High profile cam shaft 280 maybe (include cam pulley/crank pulley pon tukar skali)
2: Intake manifold (skunk 2 kalau boleh masuk)
3: Injector for sure
4: Fuel Rail
5: Clutch kit (super single maybe)
6: Tb ape brand yg sesuai?
7: Port Polish head (but xtau nk hantar mana area JB/P.gudang)
8: Ekzos sistem (4-2-1 or 4-1)
9: ECU (pakai apa bagus?)
dking91
121
11
pekan
1.high cam: comfirm nk pkai high cam?? minyak parak... cam stended pon dh ok.. 252in/248out
2:xpyh pkai brg skunk2 yg mengarut 2..tiruan sume...selagi intake asal support mod yg dibuat, gnekn je
3:210cc pon dh ok..sye pon pkai yg asl lg
4:fuel rail:sye xnmpk pe keperluan menda ni..bkn racing car kn???
5:clutch:ok jgk..tp blh tahan ke dlm jem? :)
6:cri tb perdana sei 2.0
7:anta ke nasty port flow/powerzone
8:4-2-1 powerzone extractor+1.8 piping+ 2inci mid-bullet+2inci muffler inlet(kalo heavy mode,size piping blh 2inci)
9:safc 2 pon dh ok..nk pkai emanage rsenye xblh nk tuning ignition sbb pkai distributor stended bkn coil(xpasti)
acan045427
19
yeah mmg kena fikir semula ikut keperluan mode. sy pakai cam 272 mmg bnyk membantu la dlm increase hp tp kena sacrifice fuel consumption sket.
bro rebore piston pkai model sama gak @ performance? costing? sbb belum tergerak nak tuka block 1.8 lg hehehe
Dear Owner,
Would appreciate if you could share you precious oldskool, vintage, classic car picture here..
Please keep it clean and comments and etc are not welcome.. this is strickly for pictures only.
Thank your for your co-operation.:adore:
---------- Post added at 07:20 PM ---------- 6 hour anti-bump limit - Previous post was at 06:22 PM ----------
Copy past from Mr. 1972Mini1000Auto thread, Gorgeous
'66 Dodge Dart 270...
