Buying a Lancer Evo?
huakenny
LB Performance
9,126
240
Kota Kinabalu
i owned E9....been use for almost 7 month...check engine light sometimes off and on...btw its always on.....anyone can share something regardless this problem:stupid:
---------- Post added at 02:42 PM ---------- 6 hour anti-bump limit - Previous post was at 02:41 PM ----------
and owh ya.....my evo ( is for continue installment....heehhe......
the quick and accurate way is diagnose it with OBD II Scanner...u gotta get the trouble code and check the said problem/sensor connection
DinDin6491
52
hi all...I'm new to the jdm scene.looking to get an evo(7-8) .. I have been following the MLOC threads carefully to look at the costs .maintenance.and any issues to look for when buying a car.Today i test drove this particular one i found.
Mitsubishi Evolution 8 Turbo 2.0 - Cars for sale Kuala Lumpur - Mudah.my
quick question....is the standard clutch that hard to press or is it something adjustable or something wrong .feels like driving a lorry.at least compared to another manual i drove which was the satria neo R3 ( the 145hp one) .and clearance on this matter would be highly appreciated thanks !!
MiNiFans
405
69
Erm high performance car doesn't have light feeling clutch (correct me if Im wrong)...I tried evo and civic ek,I feel both heavy than lorry :hmmmm:
PabloIceman
3,083
291
1,683
depends what type of clutch the car has on it... if racing clutch twin plate so far the 'lighter' feeling then it is OS Giken ..
vspec
Rookie
345
74
Tehran
My clutch is stock but it doesn't feel like a lorry
ixeo
4,788
3,080
KL, Malaysia
Which lorry did you compare it to? I find the clutch on the Daihatsu one relatively light.
leslie
2,946
230
5,163
have a look on what clutch it is.. stock clutch in evo is quite comfortable. if its hard.. it might be those old type exedy single plate racing clutches.. the old exedy ones are quite hard...
maxgil05
62
2
3,008
Cheras, KL
Which Evo to buy, Evo 8 has no MIVEC, Evo 9 has MIVEC for Exhaust and then Evo 10 has MIVEC on intake and exhaust but is very expensive now and look same as Preve, which is better for tuning more HP from turbo?
pangyau
1,153
302
1,683
Malaysia
maxgil05,
EVO 8... install crazy stroker kit + super crazy turbo & other mod = super power already...
phobian
90
37
3,018
Want crazy power, agree with pangyau - hands down for 8 & 9. Personally I would go for the 9 if my heart can take it. Retarded aging old man like myself has gotten lazy over the years and opt for a X.
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
Agree with Phobian...
However, young heart and just love the balance between comfort, family, sports and speed... chose EvoX too. Hahah
MiNiFans
405
69
Hi to all evo-ians … just want to ask u guys…what is the common problems in evo7-9 generations?or thing needs to be extra care ?
AYC pump,transfer case,ACD & etc ?
pangyau
1,153
302
1,683
Malaysia
Common problem E7-9: Plenty room for upgrade.
This is and old car approaching 10 years approximately.
Required some attention base on your satisfaction.
AYC pump, transfer case ACD depends on previous owner.
If lack of maintenance + frequent to track/spirited drive the life span will be shorter.
But you may source the parts either half-cut or new (both also expensive)
The aftermarket also expensive and not really comfort for daily drive...
recently i came across a SpecR mag.. There's a Skyline R33 with TOMEI engine transplant in... It's exhaust system was fitted with a silencer.. Will it restrict the exhaust gas flow??
Some forumers said it wont.. some says yes..
which 1 ar??
can someone explain to me??
i'm dumb la ... wht to do...
