SR20 Neo VVL into B13
cmng
3,289
72
the ABS light and Airbag will on
Airbag on due to sensor issue.. normally people just remove the bulb only
ABS is due to you not able to refit all the ABS sensor and connector to your car
to refit you need to have B13 ABS knuckle and pull all the ABS sensor and tap it
mostly for halfcut. the ABS sensor is cutted
so to solve this problem is same. remove the bulb saja
:biggrin:
rapinsoul
232
4
:biggrin:
thanks brader cmng, the front sensor is attached but in my case the rear is drum break originally, now i have to source out for a N15 Rear disk break
cmng
3,289
72
you need to have B13 Rear disc brake with ABS sensor
for me my advise get rid the ABS
it give you major headache also
i not a fan of ABS and i prefer without ABS as well
just get B13 Rear disc brake with knuckle only
nowday got some people mod N15 knuckle on B13 but by welding method
rapinsoul
232
4
front i am using brake calliper, knuckle and disk from the N15 half cut so if i put rear from B13 i have to buy 2 separate set of brake pad am i right? is a N15 Rear brake set pnp to B13?
cmng
3,289
72
Front N15 is plug and play to B13
Rear N15 is not plug and play.
as you mentioned you still using drum
you need to get B13 Rear Disc brake knuckle
many i know use malaysia boleh style which is welding method
Do your halfcut doesnt come with N15 Rear disc brake ?
rapinsoul
232
4
:biggrin: thanks for the very useful info, lucky i didnt buy the N15 Rear Brake set as i dont want to use the welding method, no my halfcut just came with the front set as for the rear set they are selling separately so that's why i wanted to check first before i purchase it.
cmng
3,289
72
but looking for B13 Rear Disc brake knuckle is hard
not easy to source it nowday
and it priced around 500-700 range
rapinsoul
232
4
I actually had this in my mind, i wanted to put a 4 pot for front and 2 pot for rear from R32 if i were to do this, does it need to be done by the welding method? :banghead:
cmng
3,289
72
you can do that
Front swapping it with N16 knuckle
Rear doing bracket to fabricate it and to fit the rear drum kit over
the issue
min 16" rim with offset
PCD 114 x 4 rim
4 pot brake front and rear
Rim 16 with right offset
Fabrication work
and brake bias issue.. friend do this before and have brake bias issue
rear too lock
need to get brake bias adjuster to counter it
that is another $$
calclulate the whole project cost and you think worth it or not lo
rapinsoul
232
4
Wow too many things i think i just gor for the B13 rear brake kit, unless i go for crazy mod then i might consider other setups.
---------- Post added at 12:43 PM ---------- 6 hour anti-bump limit - Previous post was at 11:52 AM ----------
Next i need to do up my exhaust system, i am not removing the cat which came with the half cut, i got a good offer for a HKS Box inlet is 2.5"
Question : Can i connect a 2.5" piping from the cat straight to the rear and place the exhaust? i am not a fan of heavy loud sound.
rapinsoul
232
4
Finally my engine transplant is over, now i am planning to go open pod, these guys were telling or asking me how many inch do i want to go for open pod, any idea how is using SR16 with 2.5" inch piping what size of open pod should i go for? i am thinking of blitz
ddv_nk12
1,228
236
PD
nice build bro. keep posting more pics.
MKMD428
876
190
5,043
johore
2.5 inch is the best. this type of engine loves to breathe..as i am also a previous owner of this engine.
open pod size? do you mean the size of the filter or the diameter size itself that fits the MAF?
nothing to worry about the open pod size bro, as long as it is open pod type is enough. you should worry about the adaptor though.
rapinsoul
232
4
I just called N1 racing in sunway and they told me that i have to custom make the intake piping from a exhaust shop and they will fit the open pod filter, i don't really understand that, anyway could anyone here suggest me where can I go and get my Open Pod Filter installed :adore:
MKMD428
876
190
5,043
johore
buy adaptor la bro..adaptor that suits your open pod. no need to waste money doing SS or whatever piping just for the sake of want to use open pod.
I bought a crime fighter alarm about a month ago. The alarm was what i consider as SHIT alarm as the problems occured one by one. First the proximity unlock is TIPU one. Then the spare remote control was unuseable. I called the seller, Auto Option. But the seller said nothing la. Then i email Megatronic Malaysia but the company never respond. After that the Big problem occured. The alarm module got problem. I called the seller again but she bla..bla..bla.. So now i cannot claim for the...
