4age upgrade to 7age..
meg_omen
421
96
3,028
Home - Klang; O
just an info...
the only reason i didn't choose this route is the flywheel bolts which has only 6 bolts...:bawling:
some sites i've mentioned in other post shows the flywheel 'give way' and cut off everything...
luckily it's in a FR, otherwise people might get killed...:rofl:
D7zul
2,697
848
Shah Alam
just an info...
I thought this setup only use 7A engine block. The rest using 4A parts.
I might be wrong :biggrin:
turbo10
626
47
3,028
sg petani kedah
just an info...
it's not the 6 bolt pattern that destroys flywheel..even early model 4g63 turbo have 6 bolt flywheel.
it's because in any engine 6 bolt or 8 bolt the flywheel would break if improper installation/mods/ lightening done to a stock flywheel or weak bolts..you can also use the bolts from 4age ones which are stronger or replace it with the ARP one..:driver:
meg_omen
421
96
3,028
Home - Klang; O
dzul... you need 7A crank which only has 6 bolts...
turbo10... yup might be the cause but i feel it's still risky...
coz even the current is having 9400 rpm cut-off...:biggrin:
probably going to 1.8 but another route...:hmmmm:
turbo10
626
47
3,028
sg petani kedah
yes meg..there are better option..say..1.8L 2zzge more powderful! :top: but u dont need 1.8L if u are having that rev limit..already powerful bro :)
D7zul
2,697
848
Shah Alam
update..my knock sensor problem repaired and solved..now no more check engine..the idle really smooth..ran as good as before..:driver:
nice.. good for u....
mayb can share a few pictures :biggrin:
D7zul
2,697
848
Shah Alam
this sound nice..
a fren also recommend 2zzge..
how bout it's spareparts?
i'm afraid if convert then no part.. mati woo.. :banghead:
D7zul
2,697
848
Shah Alam
a quick search on d net & i found that 2zzge before 2003 got lots of problem.. sumthing to do with bolts on the engine head.. after 2003 ok kot..
7age most of their problem is setting it up for higher power..
D7zul
2,697
848
Shah Alam
i can't get 7AGE off my mind.. so i did a lil more research
and come out with a list.. mayb i'll post another official build thread once this engine is running in my car :biggrin:
- Blacktop 20v head with VVT pulley for intake & adjustable for exhaust cam
- Tomei Poncam 264in / 256ex
- 7A block, oil pan
- Spool 1900cc stroker kit (piston, rod, crankshaft & all those small things) it's forged & with 8 bolts crank..
- 16v 4AGE timing belt
- FGK 4AGE 4-2-1 extractor with a lil extension to clear the oil pan
- a lil modification on the mounting to fit my Levin AE101 body
- a lil extension here & there to make all the fluid running perfectly
this is my 5yrs plan for my car.. coz the price for those aftermarket parts is not cheap..
if u guyz have any experience, kindly advice on my list of things to do & buy :biggrin:
Drove over to the Sepang International Circuit this past Sunday to cover a racing team for the upcoming Sepang 1000km race. So while I waited around for them to finish testing, I figured I might as well do a spot of picture taking of the rest of the cars there for the open track day. Didn't really have time to give it a 100% so if you were there and your car's not in this...
