Wrap extractor for longer fan's motor lifespan (& reduce engine bay temperature)
jebatdex
430
18
518
Skudai, Johor
Stock extractor (Wira) they have like a cover/heat shield that seats between the extractor and the aircond and radiator fans. Now I changed the extractor, the extractor is bigger than the stock one and seats closer to the fans. The mechanic I met advise me to wrap the extractor so it will reduce the amount of heat from the extractor reaching the fan's motor (longer motor life span).
How true is this? It will also reduce engine's bay temp right?
Please do comment.
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Please do comment.
It might melt the fan since its plastic. Bigger and nearer to it right?
D7zul
2,697
848
Shah Alam
better get it wrapped..
or u can ceramic coat .. but this is expensive :wink:
jebatdex
430
18
518
Skudai, Johor
Where u guys know a good workshop that can wrap properly for me in klang valley? How much?
D7zul, how expensive it is?
Please do comment.
Seen many just left like that. If moving the air will cool the extractor. When fan runs it will do the same...Original is cast iron block...
Supra_Fanatics
Beyond 20,000 RPM!
20,685
3,998
Ceramico is good :biggrin: But price also good.
D7zul
2,697
848
Shah Alam
RM1xxx got quoted from Ceramico in sunway..
i think u better wrap it urself.. or get any accessories shop to wrap it for u :wink:
Supra_Fanatics
Beyond 20,000 RPM!
20,685
3,998
RM1xxx is for extractor alone? Or also other parts around that price bro?
Supra_Fanatics
Beyond 20,000 RPM!
20,685
3,998
KenDiriwan
1,283
225
kendiriwan.multiply.com
Remember that the wrap will not hold tight forever. So schedule a long term check on it just to make sure.
ken yeang
6,618
1,327
Jebatdex,
I have seen proofs that extractor's heat can either
1) shorter life span of the electric fan motor (esp. the aftermarket fan has no heatshield).
2) warp the cage of the electric fan due to heat of extractor (again, the aftermarket's one made of low quality plastic)
My observation is based on NA cars, not turbo cars.
Anyway, the heat will not instant effect the fan. Takes some time to spoil the fan unit.
jebatdex
430
18
518
Skudai, Johor
This is the photo:
The gap (highlighted in red) between the motor and extractor is (for me) very close. Or maybe I just wrap that particular area of extractor which is closest to the motor? hehe no need to wrap the whole extractor? :confused:
hi ken, my car is 1996 1.6L Satria 4G92, absolutely NA
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
This is the photo:
I seriously think it will melt the fan since its plastic. How about making a custom heatshield.
Should be cheaper?
ken yeang
6,618
1,327
Jebatdex,
From the photo, I would recommend you to
1) wrap the extractor entire length. (fyi, 1 roll of wrap is about 20meter for about RM25. Maybe cheaper if you get discount. Need 2 roll to wrap it properly for your case)
2) raise the hood hinge, to let trapped hot air escape from engine bay (better result, DIY some louvers on the bonnet)
This would reduce heat built-up in the engine bay, and lessen the chance of melting the fan. The heat issue need to tackle bit by bit through trial and error.
slipar
500
61
banting - pj
im in trouble la like this..
been using aftermarket extractor for years now..
in jebatdex photo can see the gap between extractor & fan..
in my car gap cannot see anymore..like only few mm only..the metal cover behind fan motor also have to remove to clear the extractor..
i think wrap also the wrap cannot clear the gap..hahah..
time to change extractor la..will attach pic if possible..:bawling::bawling:
Then yours was badly done.....:banghead:
14th Tokachi 24 hour races/laces (7/14 15 - 16)<b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b>
The Tokachi international speedway (1 lap 5.091km)synoptic customer mobilization: 37,900
Translated Text
DENSO SARD SUPRA HV-R beautifully decorated the synthesis victory which becomes racing hybrid first with the Tokachi 24 hour races/laces of FIA international status. As for the...
