White Smoke on 93T
danish
Hi buddies,
Need help from you guys to tackle my 93T problem.
Sometimes it has white smoke somtimes its gone.
I could see through my rear view mirror.
What is my problem?
Turbine?
Bro,
Mee too facing similar problem. Last time boosting at 1 bar got white smoke after release the throttle (happen quite often). Now boost std 0.7 bar got little bit smoke (sometime). Also puzzle ???
turbine?
piston ring?
valve seal?
Fed up cause engine oil need to top up every weeks.
jin where you servicing turbo ..at tong or speed spin.. service turbo just service only but no balancing .. or complete lum sum..
Could it be from the engine oil that i am using?
Me using Mobil 1.
