what is SR3??
JiFaTT
ampang
im sorry to ask this kinda question,but everytime i go to kedai potong and ask for parts they refer my car as SR3..is it my car or its engine code.but why i ask for suspension oso they said SR3?
one more thing,civic 93 got 1.6 sohc non-vtec ka?i look around honda engine spec and dont see civic 92-95 like that? there are D16Z6- 1.6L SOHC VTEC 92-95 Civic.so,is my car sohc vtec oso?coz as far as i know D15B SOHC 3-stage VTEC punya cover dont say vtec oso..
SR3 a.k.a 2 drs EG, whereas
SR4 a.k.a 4 drs EG ..
they are referring to model, not engine code or whatever ..
SR3 and SR4 can share few parts ..
I believe yur car is SR3 with 1.6 single cam .. w/o vtec
SR3 with vtec only 1.5 sohc vtec ..
the 1.5 sohc vtec with 3 stage vtec only in EK
Clap clap clap clap.........lespek sama this mat stim.......
3-stage VTEC
Examine the SOHC VTEC and SOHC VTEC-E implementations. The clever Honda engineers saw that it is a logical step to merge the two implementations into one. This is in essence the 3-stage VTEC implementation. 3-stage VTEC is implemented on the D15B 1.5l SOHC engine in which the VTEC-E mechanism is combined with the power VTEC mechanism.
Many of us probably has laughed at the poor ignorant layman who said "I want power AND economy from my Honda". We know of course that power and economy are mutually exclusive implementations. Honda decided not to abide by this rule. Now, with 3-stage VTEC, we get BOTH power and economy !.
The diagram below illustrates the 3-stage VTEC implementation. The intake rocker arms have two VTEC pin actuation mechanisms. The VTEC-E actuation assembly is located above the camshaft while the VTEC (power) actuation assembly is the standard wild-cam lobe and rocker assembly.
Below 2500rpm and with gentle accelerator pressure, neither pin gets actuated. The engine operates in 12V mode with very good fuel combustion efficiency. When the right foot gets more urgent and/or above 2500rpm, the upper pin gets actuated. This is the VTEC-E mechanism at work and the engine effectively enters into the '2nd stage'. Now D15B 3-stage works in 16V mode (both intake valves works from the same mild cam-lobe).
Stage 2 operates from around 2500rpm to 6000rpm. When the rpm exceeds 6000rpm, the VTEC mechanism activates the wild cam-lobe pushing the engine into the '3rd stage', the power stage. Now the engine gives us the full benefit of its 130ps potential !
The 3-stage VTEC D15B engine is used on the current EK-series JDM Civic/Civic Ferio VTi/Vi together with Honda's new Multimatic CVT transmission. Stage-1 12V or "lean-burn" operation mode is indicated to the driver by an LED on the dashboard. The 2500rpm cutover from lean-burn to normal 16V operation in fact varies according to load and driver requirements. With gentle driving, lean-burn can operate up to 3000rpm or higher. Stage-3 may not always be activated. The Multimatic transmission has a selector for Economy, Drive, and Sports mode. In Economy mode for eg, the ECU operates with a max rpm of around 4800rpm even at Wide-Open-Throttle positions.
The essence of 3-stage VTEC is power AND economy implemented on a 1.5l SOHC PGM-Fi engine. Many people mistakes 3-stage VTEC as a "superior" evolution of the power oriented DOHC VTEC implementation, describing DOHC VTEC as "the older 2-stage VTEC" and implying an inferior relationship. This is totally wrong because DOHC VTEC is tuned purely for high specific output and sports/racing requirements. 3-stage VTEC is in truth an evolution of SOHC VTEC and VTEC-E, merging the two implementations into one
achor said:
got v tec with 3 stage ar? why never know one? =)
stimGILER said:
3-stage VTEC
d15b 3 stage vtec only available for jdm ek3, both sedan and hatchback.
funny thing i heard last time some said this 3 stage vtec is much more superior than b16a Sir...hahahaha... coz 3 stage vtec worr.... LOL
becoz mebe they thought that this b16a also got 3 stage vtec .. :tongue: :tongue:
