the car using external wastegate now.normally how long will mechanic takes to check the problemOriginally posted by antonio@Feb 24 2005, 12:16
u have to open the 4 screws on the exhaust side of the turbo and u will see 2 holes...1 is exhaust wan n 1 more is the internal wastegate holes...usually the wastegate section is prone to crack....thats why the turbo misses to compress the air that is being suck ....it closes to make sure all the exhaust gas pressure will be pushing the turbo fins on the exhaust side n when certain boos is reached the actuator will open the wastegate for letting the Ex gasses to flow through it...it will be pushing the turbo not so fast lar when wastegate open....
melvin,ken hereOriginally posted by sum-dum-fuk@Feb 24 2005, 20:09
lan..
what car u using ?
what did u modify lately ? hardwares...like ?
intercooler changed ?
larger intercooler pipings ?
what turbo u using ?
joe,no management woOriginally posted by Joeker@Feb 24 2005, 22:30
Ken,
air flow buang? got engine management oledi?
how to set the wastegate?Originally posted by flamefox850@Feb 24 2005, 22:27
wrong wastegate setting ? maybe the spring too soft ? intercooler piping also play roles here. too big will cause more lag (i think the correct term is boost threshold..not lag)
what does this means ahh?? :rolleyes: :huh:Originally posted by Sky88@Feb 24 2005, 23:20
just another idea may be piping or intercooler get a good bar and plate u will feel the different
ha?dunno wo.have to confirm 1st.boosting 1 barOriginally posted by antonio@Feb 25 2005, 10:42
set by he springs inside the w/g itself or sumtimes got top screw like Bov style...but by adjusting do you know how many boost u r getting...any indication??but the again maybe the w/g opens easily so the turbine cannot spin fast enuff to get instance boost reaction....
no airflow???no managemnet oso???uik standard ECU can use w/o airflow meh???this is new nie??then mr karman sure will be spitting in his grave...hahahahha...i think u mean no air filter kot...but then mebbe i'm wrong... :lol:
i/c piping can do some lag's issue oso...out of specs pipings or bending too far like traveling on a highway oso promotes to lag....but in ur case i think its either w/g or i/c piping... :lol:
how long??depends la on the confirmation of problem...try n seek professional help from diffrent² ppl lah to see their opinions on what is wrong.... B)
