Tips for Easing Neck Pain
wj_03802
Get rid of that pain in the neck by heeding the advice that follows.
1.Take a load off. One of the simplest ways to relieve the pain is to lie down and give your neck muscles a chance to recover. But don't use a thick pillow that crimps your neck.
2.Ice it.
Ice effectively numbs pain and decreases inflammation. Put crushed ice in a plastic bag and cover the bag with a pillowcase (a terry towel is too thick to effectively transmit the cold). Apply the icepack to your painful neck for 15 minutes at a time.
3.Heat it up.
Heat increases circulation and can be effective for easing stiff muscles. Use a wet towel or a hot water bottle, or stand in a hot shower. But don't keep it up for too long. Too much heat can aggravate symptoms and cause more pain. You might even want to try following up your heat application with a few minutes of cold treatment.
4.Relax.
Emotional stress can trigger muscle tension. Pay attention to what stresses you: your drive to work, your rush to get dinner on the table each night, meetings with your boss, and so on. After you've identified your common stressors, think creatively about ways to reduce your stress. One way to manage stress is through relaxation techniques, such as progressive relaxation or abdominal breathing.
To perform progressive relaxation, find a quiet place where you won't be disturbed. Sit or lie down and close your eyes. Then, starting with your head and neck and working down the entire body, consciously tighten, or tense, and then completely release the muscles in the area.
To perform abdominal breathing, sit quietly and take a slow, deep breath all the way into your abdomen; place a hand on your abdomen to feel it expand and confirm you are breathing deeply enough. Then exhale completely, gently sucking in your stomach. Breathe slowly and deeply like this for several minutes (if you do this too quickly, you may begin to hyperventilate).
Other relaxation techniques include meditation, yoga, and exercise. In addition, you may want to develop some of your own methods of relaxation, such as engaging in a hobby or listening to peaceful music. Do whatever works for you.
5.Use massage.
Massage can help ease tense muscles and give temporary relief, and it may help you sleep better. First, take a hot bath or shower to relax the muscles. Then, have your partner use oil or lotion and rub your neck and shoulders using the fingers to apply gentle pressure in small circular motions. Next, have your partner rub your neck and shoulders using firm pressure and long, downward strokes. Don't forget the chest area. If you don't have a willing partner, try rubbing your own neck and chest area with oil or lotion for 10 or 15 minutes.
6.Take a nonprescription pain reliever.
Over-the-counter pain relievers such as aspirin and ibuprofen can ease the pain and reduce inflammation. If you can't take these medications because of allergies, stomach upset, or any other reason, try acetaminophen; it won't calm inflammation, but it should help relieve pain. For a list of precautions to take when using over-the-counter analgesics,
7.Practice good posture.
Posture has more to do with neck pain than people realize. The head and spine balance in relation to gravity. When poor posture pulls the curve of the lower back forward, the upper back curves farther backward to compensate. In response, the neck curves forward, in a strained position.
You can use a wall to help align your body properly and improve your posture: Stand with your back to a wall, heels several inches from the wall. Your buttocks and shoulders should touch the wall, and the back of your head should be close to the wall. Keep your chin level. Now, step away from the wall. Step back and check your position. Try to carry this posture throughout the day.
8.Get and stay trim.
Being overweight strains all of the body's muscles, including those in the neck.
9.Strengthen stomach muscles.
Just as poor posture and obesity can cause straining of the neck muscles, poor tone in the stomach muscles forces the upper back to curve farther backward and the neck to curve forward. Do exercises such as bent-knee curls (they're basically sit-ups, but you only lift your head and upper back, rather than your whole back, off the ground) to strengthen abdominal muscles.
10.Do neck exercises. Two types of neck exercises can help ease and prevent neck pain: gentle range-of-motion exercises and isometric exercises. Apply moist heat to the neck before performing the exercises. Each exercise should be done five times per session, three sessions per day.
Range-of-motion exercises help stretch neck muscles. Sit erect but relaxed. Slowly turn your head to the right as far as you can, hold, and return it to the center. Repeat to the left. Then drop your chin down slowly toward your chest, hold, and relax. Bring your head back up. Now tilt your head toward your left shoulder, hold, and return to the center. Do the same on the right side.
Isometric exercises are performed against resistance but without actually moving your head. Try this routine:
  1. Sit erect and relaxed, hold your hand up to your forehead, and press your forehead into your palm, using your palm to resist the motion.
  2. Place your right hand against the right side of your head, and press your head against your hand (as if trying to bring your right ear to your right shoulder), but use your hand to resist your head's motion. Do the same on the left side.
  3. Press both hands against the back of your head as you try to push your head backward; resist your head's backward motion with your hands.
  4. Press your hand against the right side of your face as you try to turn your head to look over your right shoulder; use your hand to resist the turning motion. Repeat, pressing your left hand to the left side of your face as you attempt to look over your left shoulder.
11.Stay in shape. The stronger and more flexible you are overall, the less likely you'll suffer from neck pain. Swimming is one of the best all-around exercises for strengthening the neck and back.
12.Work at eye level.
If your neck discomfort comes on toward the end of the workday, chances are good that your workstation or your work habits are causing the problem. People often get "desk neck" from looking down for long periods or from reaching up to work. If possible, always keep your work at eye level. Change the height of your chair, desk, or computer screen; use an upright stand to hold reading material; and use a stepladder, stool, or raised platform instead of reaching up.
13.Take frequent breaks.
Change your body position often, especially if you have to be in a physically stressful position. Get up and walk around at least once an hour.
14.Unlearn "neck-bashing" habits.
Do you crimp the phone between your neck and shoulder? Do you often fall asleep sitting up in a chair and wake with your head tilted way back or your chin to your chest? Do you shampoo your hair in the sink? All of these habits can cause neck strain. Become aware of habits that strain your neck and replace them with neck-healthy ones.
15.Sleep on a firm mattress. If you wake in the morning with a stiff or sore neck, your mattress, pillow, or sleeping habits are probably the culprit. Use a firm mattress and keep your head aligned with your spine. Don't sleep on your stomach, since it forces your head up. Avoid pillows that are too thick and firm; try feather or crushed-foam pillows rather than those of solid foam rubber.
kaka....i often suffer from neck pain. Hope it can relieve my neck pain:X-:
Pasar malam is selling those back rest thing that you can put on your chair. Does that shite work?
simonchangwaimun said:
worse come to the wrose,change neck
I considered that, but..i dont like the side effect lar...99.99% probability of death:shocked:
i noticed this
hehe...sorry, I'm so lame:X-:
Excel,
It should read...
Sit erect, sit a gal on your erectness and pump her up and down. Ensure that you sit upright so that her breast will be rubbing against your face and you can lick her nipples.
hahahaha
Dont play play with neck strain
i just facing it last 2 week
and bloody suffering
The whole neck only can straight. turning a bit will cause pain and burning sensation
Sleeping time is worst
It not the pain that hurt
it very uncomfortable
till you cannot do a lot of thing
i have to result to visit doc to take muscle release medicine and
some muscle release lotion
satria_95 said:
Excel,
It should read...
hahahaha
lol.... anyone here more creative than jerry?
cmng.. nice car~
satria_95 said:
Excel,
It should read...
hahahaha
Thanks for your advise, Dr. Jerry. :biggrin:
Blacksumurai.... U can try that you when ur neck pain.....Hope u can ease ur pain. ^_^..... I prefer my partner massage me. Osim or Ogawa cannot replace with human. haha.......
ka_ren,
Wanna try my creativity with me? hahaha
BlackSamurai,
Eh? Thank me for what? I thought last time you teach me to sit erect, get the gal to sit on the erection with her back facing you, then while she pumps up and down, you can reach front and squeeze her tits? hehehe
wj_03802,
BlackSamurai eases his neck pain by putting his head into a gal's "garage", then the gal will use her "garage doors" to massage his neck. Of course, BlackSamurai would have a snorkel hose from his mouth (which is inside the "garage") and the other end is sticking out of the "garage"
hahaha
Satria 95..... what do u mean gal's garage?? what i know garage is a place to keep car or a place where you can repair the car only. Can replace clearly ??
satria_95 said:
BlackSamurai,
sssshhhhhh, no need to tell in the public. :laugh: :laugh: :laugh:
wj_03802,
garage means pussy lor. hehehe just a nick name for it. hehe
BlackSamurai,
oops. hehehe sorry ar hehe
guys hv wonderful imaginations here
hahahhahaa
yayaya
a nice passionate massage which leads to sex
karen,can try oso geh
ask teh msg for u,then u juz pretend u fell asleep...
wakakkakakakak
hmm..... You guys makes me curious. Difficult for me to imagine. Headache....swt swt...
just chop off your head then no more neck pain or even headache...:regular_smile:
True also..... chop off the head, ma no more neck pain.... wa so smart..... Jaydee123. haha..... That time I already die.
hahahhahaa
yayaya
wakakkakakakak
after pretending to fall asleep.. then wat?
lol
u teach ppl half way wan.... i wan refund! lol
