here some info i got from internet about cappucino :o
DIMENSIONS AND WEIGHT
Overall length 3,295 mm (129.8 in)
Overall width 1,395 mm ( 55.0 in)
Overall height 1,185 mm ( 46.7 in)
Wheelbase 2,060 mm ( 81.2 in)
Track - front 1,2210 mm ( 47.7 in)
Track - rear 1,2210 mm ( 47.7 in)
Ground clearance 135 mm ( 5.3 in)
Gross vehicle weight 895 kg (1,973 lbs)
Kerb weight 725 kg (1,599 lbs)
Min turning radius 4.4 m ( 14.4 ft)
Seating capacity 2
ENGINE
Type 3-cylinder, DOHC, 12-valve, turbo-charged/intercooled with 3-way catalytic converter
Piston displacement 657 cc (40 cu in)
Bore and stroke 65 x 66 mm (2.55 x 2.59 in)
Compression ratio 8.3:1
Fuel distribution Multi point injection
Maximum output 63.1bhp @ 6,500rpm
Maximum torque 62.9 lb ft @4,000rpm
Fuel tank 30 litres (6.6 gallons)
TRANSMISSION
Type 5-forward all synchromesh, 1 reverse
Gear ratio 1st 3.478
2nd 2.021
3rd 1.352
4th 1.000
5th 0.790
Reverse 3.260
CHASSIS
Suspension front Double wishbone
rear Wishbone/multi-link
Steering Rack and pinion
Brakes front Ventilated disc
rear Disc
FUEL CONSUMPTION
Urban cycle 39.2 mpg (7.2 L/100km)
At a constant 56 mph 52.3 mpg (5.4 L/100km)
At a constant 75 mph 36.7 mpg (7.7 L/100km)
