clubbing friday bump! :)
edwinwee said:Testmonial:
Hi all... I personally used Superspark 3 years ago since i bought my car which is 2nd hand and i'm really satisfied with the performance i get.Before fixing superspark my car really lagged in power.Now it's superb.If i don't use this product i'll never recommend this to others. It cost me RM299 when the product first launch. Now it's damm freaking cheap guys.It's worth the $$ to spend and it last long. Auto and manual car can be installed. You'll fell the different after fixing superspark. Below are some of the description of the product:
Superspark is a revolutionary technology of allowing engines to gain more power and tourque by burning fuel completely and efficiently
Benefits of superspark:
1. Increased horsepower & torque
2. Better fuel mileage
3. Easier engine starting
4. Quicker acceleration
5. Higher top speed
6. Smoother running
7. Less carbon built up
8. Less pollution
SUPERSPARK increases engine power by generating powerful and optimised spark duration for more complete burning of fuel. Engine's efficieny improved without consuming any additional fuel. with better combustion,carbon built up is thus reduced and engine gets cleaner and longer lasting.
SUPERSPARK revolutionary circuitry optimised the rise and saturation time of inductive coil with added storage energy to provide the perfect solution."SUPERSPARK" allowing engine to increase POWER without extensive mechanical modification, fuel wastages and minimizes hazardous emissions by simply burning fuel efficiently !
FOR PETROL ENGINES ONLY, THIS PRODUCT WORKS FOR BOTH ELECTRONIC AND POINT INDUCTIVE AS WELL AS MULTIPLE-COIL IGNITION SYSTEM.
huakenny said:brother,
this thing made in where a?:Not_Impressed:
jeremylee81 said:im going to install it on EFI, my mech (hometown) did tought me how to install it, now i just need a pic to comfirm, i got the wiring tools already, to check which cable is connected from the ignition starter to the distributer. just need to cut the wire and put in the S.Sparks...also 1 more wire to ground. hehe!!
Red cable: connect to the cable from the Ignition starter
Blue: connect to the socket that need to connect to the distributer.
Black: ground!
right??
ocphangaz said:red from Ignition... not ignition starter... basically.. remove the + from the coil. connect it to the red wire from super spark. then connect the bluewire to the + on coil. then ground the black.
you won't go wrong this way.
ps. Good seller got item within 24hours of bank in.
huaren1978 said:i've got a few questions here
1. is this product similar to stromberg?
2. does it affect the air-fuel ratio? which leads to my actual worry.. izzit safe to install on a turbo engine?
3. does it improve the fuel consumption, can get better mileage?
jeremylee81 said:As for me, i feel the engine smoother at low rev, and also no more jerking lo!! as for performence, the fev can goes up smoother. just like wat ocphangaz said!! nice product!!
