@{SASUKE}@ ECU tuning solution for Honda engine
sasuke
Over 10,000 RPM!
We are selling a tuning solution for all the VTEC engines with Crome ROM Editor. This is a cheaper solution, but with extremely good features and value. This Crome ROM Edition solution is from U.S.A. It is work exactly same as one of the popular U.S.A. tuning solution (Hondata), but Crome has even more features.
What is Crome? Simply put, Crome is an OBD1 Honda ROM Editor which lets you edit and add extra features to your stock ECU. This gives the ability for one to run a Honda B/D/H series engine with forced induction systems (ie. turbo, supercharger) or individual throttle bodies. Find out more by continuing to the product information page.
Features
I've summarize the Crome features for VTEC as follow:
- Standalone ECU
- Realtime programming
- Accurate airfuel and ignition timing tuning that suit your current setup
- Injectors setting
- Advanced table editing
- Increase RPM limits up to 11,000 RPM
- Full throttle launch
- Air con cut off
- Safe from theft
- Add datalogging capabilities **
- Many more, please refer to here.
** Advanced features need extra plugin and components
Portfolio
Honestly speaking, we still haven't try it on Turbo engine yet. We have tried to tune all the B series engines already. Below is the dyno chart from one of our customers car with B18CR with Toda C cam.
Another dyno chart from B20B
Price
Rechipped user = 450 (Total)
EPROM chip - 50
Tuning - 400
Stock standard OBD1 user = 500 (Total)
EPROM chip with installation - 100
Tuning - 400
OBD2 or TypeR wiring user = 1300 (Total)
OBD1 ECU with EPROM chip installed - 500
OBD2>OBD1 converter - 400
Tuning - 400
* for 99-00 TypeR wiring (OBD2b) user, please call.
** for Sabah & Sarawak users, please call.
*** Dyno cost is not included here.
**** Retune is RM250 for future upgrade.
Contact
Please contact Simon 017-8708550 for inquiries. Thanks you.
Bro, I using B16A with B20B block wiv original tuning. So i is under Rechipped user=450,Stock standard OBD1 user = 600 or TypeR wiring user = 1200? Please advice.....
If you ECU is never rechipped before, you are under stock standard OBD1 user = 600. Thanks.
my chip have change before.....so still under the RM600 or RM450? If i want do with dyno at machine, do u provide? or u only tuning at high way....Please let me no the price for Crome tuning & Dyno . Thanks. Now my car eat a lot fuel since use H22A injector.....
Please call me to discuss or sms ur contact at least. If your ECU has been rechipped before, it will cost u only 450. We will do it on dyno, u deal with the dyno shop. Normally, they charge 200 for tuning run. Thanks.
Bro, what about K series engine for new civic 2006, K20Z ? Thanks.
hi bro, does it have any diff if doin it on the d16 sohc non v-tec engine? just minor mod. thanks alot for the info bro.
Definitely got different. Just we don have the base map for D series yet. So, at this moment we cannot tune D series engine yet. Thanks.
your pm is full. I e-mailed you with questions.
How many customers have you guys managed to successfully tuned so far?
Bro, i've got re chip my 16a b4 at amoil.. now i install the 20b block n got vafc..
is it affect when i want to rechipped again wif ur Crome chip??
Pls... Need some advice...
If you have rechipped, just take back your chip. We will use new chip. No effects. If you do not satisfy with Crome, just plug in back your chip and VAFC and it will be back to normal. Thanks.
Tuning is done at the dyno machine?thats mean we have to pay extra for dyno cost.My ecu has already been rechipped and my setup are ls vtec.Pls pm me.I'm staying in Puchong area.
By that, if i'm interested with this ECU...
i got to naik kl eh??
Yes. If not we cannot custom the setting on ur monster. If we just simply give u the chip, it will not accurate and might got problems.
Ok bro.. Thanx bro..
How would i contact then...
i might interest on this..
that mean my old rechipped ECU mesti buang ar!!
Rechipped ECU can use back. Not "buang". Can save money if u have a rechipped ECU.
