Complete Honda OBD1 Tuning Kit
dh3x
Have the following items up for sale (enthusiast will know these items):
SST Reburnable EPROM chips (10 pcs)
This chip is reburnable 1000+ times and compatible with the most popular chip burners used (BURN1, Willem, Pocket Programmer). These chips can be used with the 2Timer to store and switch between two different programs as well. Make sure you know if your eprom programmer is compatible with these chips (SST27SF512).
BURN1 Chip Programmer
USB Chip Programmer works with the AT29C256, 27SF512, and AM29F040 chips. Self-powered from the USB port, so no power adapter is needed! Burner can also be used to read stock GM memcals using the HDR1 adapter. While it will only program the three types of chips listed, please note that those three chips can be used as drop-in replacements for most EFI applications. Comes with stand-alone chip programming software (available for download). Also compatible with TunerPro RT and soon to be compatible with Crome and TurboEdit! Will read most stock-style chips (2732A, 27C128/256/512/etc).
Ostrich EPROM Emulator
The Moates Ostrich is an EPROM EMULATOR. What that means is it pretends to be a chip in your ECU. Simply put, it is a box of circuitry with a ribbon cable that connects to your ECU in the same spot the chip would go. Attached to a laptop and a compatible ROM Editor...you can make live updates to the fuel and ignition maps in your ECU, as it runs.
This is THE standalone USB emulator. It might be the ONLY one. It will emulate 2732A, 27C128, 27C256, 27C512, and more! Up to 4mbit (29F040) 8-bit emulation. Robust, USB-based realtime EPROM emulation in the palm of your hand! Battery backup lasts 75 years (standard AAA), so you can leave it in the car if you want to. With this device, you can upload an entirely new binary without a hiccup while the car is running. Or, you can change one parameter at a time. Fully compatible with TunerPro RT, TunerCat, Uberdata, Crome, Hondata and now...TurboEdit as well!
The Ostrich can be removed and you can burn a chip and put it in the ECU. Or you can leave the Ostrich in your ECU full-time.
USB Datalogging Kit
This USB data board converts RS232 levels from a computer (ECU) down to 5 volt TTL signals. With this cable you can datalog with your favorite DIY Engine Management system. TurboEdit, Uberdata, Crome, ECU Control, Neptune and others use serial communications between the ECU and a laptop to monitor sensors and transfer data. This cable is designed to plug right in to the CN2/CN3 port on your Honda ECU with no modifications. A 4 pin male header is required to be soldered in and will included in the kit.
Innovate LC-1 *Bosch Wideband Sensor Included* RM800
Innovate LC-1 Lambda Cable with wideband Oxygen (O2) Sensor. The LC-1 is a complete wideband controller built in to a sealed cable. It features the same award-winning patented digital measurement principal found in the LM-1, and includes digital input, output, and 2 programmable analog outputs.
OBD1 VTEC ECU *ready for custom chip*
OBD2a to OBD1 Harness RM300
Info: Bought whole set of items brand new Aug 2006 for future project. ITEMS ARE ALL BRAND NEW!
Reason for sale: Tuning project never took off. Bought new car.
Deal method: COD or Poslaju
Please PM me if interested.
EPROM chips, BURN1 and Ostrich emulator are sold!
USB datalog kit sold... only wideband and harness left... hurry!
