removing existing exhaust
Danny
Is there anyway to add on a device so that you can remove the exhaust piping as an when you need it (ie during racing) & when you want it to be quiet, u can install back the pipe?
Mate,
I was thinking along this line some time back...what i came up with is that u go to any hardware shop and buy a flange(its a pipe with screw ) err how to explain ah...its two piece...one piece has pipe with thread , the ohter has a pipe with a screwable portion that connects to the other pipe then u screw them together to get one piece but its one whole pipe...i hope u understand...if not got to the hardware shop n askler..size can confrom to ur needs .....so wat u do is u weld each end to ur piping liao then screw and unscrew as needed...but then the exhaust muffler mounting should be removable wanler...not soldiried to the muffler...
speedz
flange eh? ok I'll check it out at the hardware shop, thanks for the advise.
