intake and exhaust mod (ZZT23x)
bikerz
213
i wanna use apexi dual air filter. but how to install? bcoz i have to remove the airbox but there is sensor attach to it. where to attach the wire if the airbox have been remove? do i need tho change the intake pipe? where to get? area around shah alam. can feel the difference when change air filter?
http://www.zerotohundred.com/newfor...ica-blitz-nus-exhaust-new-version-celica.html
i'm thinking to use this exhaust. is it blitz make the whole system or just a mechanic join them all? in term of performance, will there be a difference?
Barbarian
625
24
www.myjsoc.com
Re: intake and exhaust mod
the blitz exhaust is bolt on.... no welding required... I used to have this.... I think brand new was RM1200.... you will probably gain about 2-3whp with both exhaust and filter.... not noticeable....
bikerz
213
so, for the exhaust, is it value for money? or should i custom it at JFA for rm700, they will use new pipe with bigger diameter from catalytic converter till end (with new muffler). mine is auto. performance wise which is better? and the blitz exhaust, is it noisy? i'm expecting only a bit louder than stock, don't want so loud
Barbarian
625
24
www.myjsoc.com
if you dun wan loud then jus get the rear muffler.... power wise is more or less the same.... no big deal....
bikerz
213
so, beside using turbo/supercharger, what else can i do to improve celica power?
(where can install supercharger? cost? need to change stroker kit?)
Barbarian
625
24
www.myjsoc.com
brand new Greddy supercharger kit is about RM14-15k now. stroker kit is slightly above 10k..... you dun need stroker to have the supercharger....
another power adder option will be nitrous. brand new set up is about RM2.5-3k.....
Cams will be around RM3.3k.... standalone ecu 2.8k... race header 3k..... valve, valve springs, retainer 3k....
other simple bolt ons aren't gonna reap in much power......
ir1z
102
4
nice nfo there barb.....didnt know bout that
veilsideboyz
1,616
17
port polish intake manifold & header .....
engine balancing and more..... will gain more horse :burnout:
change carbon bonnet.....16" rims.....take out Gt-wing & spare tire from trunk....:burnout:
