shit.. hahahaa ur pic..
there is 2 type relay, depend which one u want to use.
normally open and normaly close
use nromaly open is simple, normaly close most is use for alarm system.
ok.. wire up normaly open relay. look on the numbers 85.86.30.87.87a
when - power to 85, + to 86. the relay will click. (terbalik also can)
so connect 85 to ground, 86 to ignition power(attach to any wire have + power when u turn on ur key. easy to find from ignition coil)
connect 30 to battery +, choose either 87 or 87a connect to fan + power that all..
so when there is ignition power to relay, it will click from 30 to 87/87a close curcuit . so ur fan will get power directly apply from battery.
