reccomendation oil for old saga engine
pathfinder
hi.
just refurbished my megavalve saga.top overhaul,new piston rings,new plugs,auto box servis,flush radiator,new shock absorbers.....
what the best oil for old engine? any reccomendation?
thank u
I'm constantly using shell engine oil. Previouslly using semi sync..now try out the fully sync.Didn't makan engine oil though.Havent try out other engine oil..but shell seems ok for me....
how much your refurbish your megavalve?
all is rm900 including labour. small time kampung mechanic.
next stage bodywork...repair dent & new paintjob.
before this use BP 20/50 purposely made for old engine that consume extra engine oil.
now have yet to decide which brand of oil. maybe shell also. better semi sync or mineral based?
any additive that could help prolong /enhance /protect the engine?
You can try semi-syn with Tufoil Engine Treatment for your car, Pathfinder.Good results can be expected.
Yup,second focal point.For shell you can try the semi sync around 70+...last 2 month i gatal coz used to have the semi sync(blue tong).So go for the black one fully sync.Some said old engine use fully sync will consume engine oil but it seems like..even after hard revving.it doesn't consume. Well,there is diff when i use the mineral and semi sync..Very significant is morning start car.
900 arr....hmmhmm....
after overhauled already consider as new engine,unless ur engine is count by year not condition
Great to hear of your sucessful combination of Tufoil with semi-syn. escaflowne.
There is no need to use a sloppy oil like a 20W50 once your engine compression is restored. Oil has to flow fast to be good. It cannot be allowed to flow like glue. Camshafts need to dance!
correction...my saga megavalve went through major overhaul.new pistons,rings etc. and the cost not rm900....it's rm1200. silap tengok bill.
i collect the car just now. question.....do i have to run in/break in the engine? some say need to, some say no need.
what dissapointing me,i already told the mechanic to use establish brand of ATF oil...but the mechanic put in strange brand of autobox oil. ARGENT ATF...dexron III/mecron. texas ,usa made. anyone ever heard this brand?
another thing let me down...i thought want to start with semi sync, but he pour shell helix super 20/50.
yep,after overhauled need run in,coz already reborn to be new engine,after certain mileage to run in well,then change to fully sync or semi sync
accordracing
u are right. it feels like new engine.engine& gear change smooth.
i will change the oil to semi syn oil after 1000km run in. since yesterday covered 200km already.
also want to change the ATF oil.....have doubt about the quality of the current oil.ARGENT.new brand ...never heard.
love my megavalve eventho it's old & outdated. all in factory spec. next stage should be new 1 layer original paint.will keep the car forever....future classic.haha
thank u for advise
haha... dun worry argent is not a bad quality but just poorer specification only .... you can get better one with that same money ...
after you break in say 1000km ... you can always try CEPSA 10W40 for it ... its one of the best fully imported engine you can get in the market ... check out their website at www.cepsa.com ...
you will see how great this brand name is .
what if use 10w/40 viscosity semi syn oil....
ok or not for the newly overhauled megavalve engine...?
I tot dexron III ATF is meant for new version auto boxes?
Our older version auto boxes should use bak dexron II ATF.
hello..just wanna share my 2 cents with you..
i'm driving an old engine as well...
curently using Shell Full syn 15/50W...just wanna try out...but i don;t recomend it to you la..because it doesn;t feel good
i'd recomend you castrol magnetic 10/40W...it's a semi syn..good run for old..previously use on my charade aura..and then also on my corolla..both also year 1991..runs well with that oil...
anyway..if you wanna go for full sysntetic oil i'd recomend MOBIL 1..damn good!!!!!
mebbe you can try Q8 semi syn?
i'll be changing to HKS semi syn on my coming oil change....
p/s-don;t use mineral 20/50 so much la...not nice..old cars need to drink birdnest and ginseng too...
essolube x2 sae30 (monograde, SF/CF-2) or caltex delo400 15w-40 (SL/CI-4).
ei alantan..i'm using shell full sync same as you.Seems ok for me at high rev...
New Posts
