rear drum 2 rear disc
hampeh
30
any one got do this before for B11(sunny 130y = sentra 83-86)....
any other model fit?
minor/major modification?
cost??? :lol:
Booze
155
My bed room "on da BED"
www.defcon.org
not advicecible..
rare braking power are not suppose to be more the the front one.. it will cause ur car to be highly unstable during hard braking.. unless u have ABS.. and EBD
Yong_5290
3,637
49
Klang
hotmail.com
but if the rear braking power is greater...i feel tat less nose dive when normal braking n also hard braking...well...juz 2 share from the situation of my car....
guest18
346
how about if front brake is upgraded ?
what combination of front+back disc brake is best for sunny
I mean get from car like n13 b12 and such or use aftermarket rotor caliper and such
vestax
1,573
7
Damansara Heigh
www.fivio.com
i don't see why you can't use the rear disc brakes , anyway the rear won't be greater then the front , if you had purchase the correct brake set . make sure the rear brake caliper piston is smaller then the front , then u`ll be fine with it . logically speaking , front has shorter travel distance then the rear , cause the fluids need to travel to pressure the caliper pistons , so the front brakes will have great response then the rear due to the short brake line , and when doing hard braking , the front will always lock first rather then the rear . if your rear locks and the front doesn't then its not a good sign , cause you`ll fish tail and lose control under hard braking .
hampeh
30
oic....
let say...
rear brake is drum...
but i want to change front disc with bigger one..
how can i do that???
My car has been vandalised with spray paint just this morning. and its barely 1 month old!! :bawling: I wonder if anyone out here can advise on the correct method to remove the paint without respraying the whole car? it has never been waxed nor polished before, just the fresh coat of paint right out from the factory.
