Rattling noise -Lantis 323f..Need help!!
eakamal
Kuala Terenggan
Hi all mazda owners..
My car starts to make an rattling noise at around 2000 rpm & gone at higher rpm.I suspect it came from engine cover panel but my mechanic said it came from exhaust system..extractor ( front section exhaust system).
Anyone who faced with same problem..hope can share some info..
eakamal,
Your car got noise during low rpm ......... hmmm.... need to hear it first. Exhaust maybe one of the culprit, but to identity noise is the most difficult thing to diagnose.
sorry can't help. I am driving a 323f too.
Had checked with 2 different exhaust shop..They jack up the car to see..But no leak or wrong with exhaust system.I also check with engine compartment & under car engine panel but everything stay tight.
The noise only happen when car on the move when rpm nearing 2000 & it gone for upper range but at stationary it didn't.I try to refer in mazda323.co.uk web page about rattling noises cause by exhaust but won't help.
What should i do:
1. Change all front suspension bush?
2. Change extractor & new exhaust system?
OR...
Anyone who have any idea / experienced it are welcome..For kfze TQ for ur comment..This noise make me nut thinking where it came from.
eakamal...
check the rubber bush that use to hang the exhaust. maybe its gone. check all the way from extractor to the end. i dont think change the exhaust will solve the problem unless there is an alien in yr exhaust.... good luck
Problem identified,came from extractor..Exhaust shop weld a bracket at the extractor..No more rattling noise..
Anyone had using hotbit extractor?i'm interested to know is it worth to buy it?
i to all mazda lantis owners here. i'm planning to get a used mazda lantis 1997 model. can you advise if this model is good in terms of handling and comfort level.
eakamal, so no more noise? i pm u about the extractor. if u know, pls tell me.
to william, which model u plan to get? sedan or h/back? 1.6 or 1.8? if u have a heavy feet, opt for 1.8 then. btw, both model are preety good in handling and superb comfort level. FC might be high for 1.6. also for the parts, i think slightly higher then those proton.
No more noise..Problem settle..i' had read ur pm,i'll try to ask my friend about it...
Will,
I'm using lantis h/b,in term of handling & ride is good but FC ( for auto model )lil'bit high but it depend how ur drive,mod ( such bigger rim,exhaust sys ).Parts still available anywhere since it same- ford lynx.
hello thanks for the information. can you indicate how high the FC is comparing the auto and manual 1.6.
by the way, does the 1.8 consume more petrol than 1.6?
eakamal...
how far can yr car go with full tank? (capicity is 50litre@rm81). on highway i go for 450km before i refill, with a bit more left. average speed is 140km/h. can yours do the same or higher. how much u spend to temerloh?
From temerloh to Bangi ( 170 km ) if i fill with Rm25.00 @ 15.34 litre ( Rm1.62 perlitre ) reach there, balance near at "E".Average speed 100-105 km/h..with aircon,1 passenger.Travel on karak highway & LPT.
I think it ok ..Considering i'm using 17' rim,mod exhaust system.If i use standard rim maybe FC much better. :biggrin:
Engineer 1,i saw u sell ur sard attack meter?Sold ?Why sell it..sayang la.Last month i'm install rsm..it looks great la..worth buy it. :rock:
:dancing2: :dancing2: :dancing2: :dancing2: :dancing2:
like that aar.. ok la. maybe i will consider a 17" also. plan to get only 16" bcoz daily use and tyre also not that mahal, but since my second car be out by next week, 17" would much nice. whats the offset i need for 17" rim? i dont want a flat look rim. btw, how much effect to my 1.6 auto engine?
will... i m not a selling any of lantis la. if 1997 model nowadays also not less then 38k i think. 1.8 shall higher a bit. unless u want 1996 model, its cheaper.
engineer 1...
got ur second car next week? ...What car is it?
According to web site lantis use PCD 100mm..Tyre should be 205/40/17.If u want to use 17",i think it would be nice u lowered it a lil'bit..looks better.
hi guys, thanks for the info.
if i drive the car in city and not going to use highway at all, which model is best for FC? I think 1.8 is better when you drive along the highway, right?
yar loo.. my 2 previous car is turbo. now stock car, patah kaki also patah hati:turtle: . so i already got a cheap used satria for my next project. GSR la i think. see budget first.
i know PCD is hundred but i not sure what offset is suitable to have garang look. u use a lower coil or adjustable? is it hard to find sports coil for lantis?
Hahaha...patah hati...? :secruity:
Ur second car also want to convert GSR turbo?Me using sport spring & normal abs.Want to use adj but new one quite expensive.Custom made HWL & GAB adj cost RM 2100.00..Second hand mazdaspeed quiet rare to find.
If u want GAB abs / sprt spring try contact galantorian (zth member-dun know real name ) he got it,
GAB sport spring RM 550.00
GAB sport abs. RM 800.00
his no: 012-238 1860 for order & delivery..How bout sephia extractor..u buy it?I think speedwork offer around RM340.00 for lantis..U can call them to confirm.. :albertein :albertein
already check... full set of exhaust will cost more then 1k. for the absorber, i check last time with titan, cost me around rm2400++ with coil without top mount adjustable kit. chehhh... everthing expensive now. also shop for bumper spotlight/fog light. suzuka halfcut at segambut offer me a set of front bumper with fog light and orange signal light for rm380. i ask for fog light only, he said take it for rm350. can u find cheaper for me?
william, susah susah je. 1.6 also can la for town use.:turtle:
U confirm with speedwork?How about extractor alone?
Yep..everything seem expensive today..Hard to find something affortable. :thumpdown
Me using hella orange fog lamp,the previous owner had put it.As RM 350.00 alone for fog lamp i think it not worth to buy..better find other alternative.
checkout this
http://www.speedworks.com.my/
extractor alone is about 330 to 340
New Posts
