R33 GTS Vibration
opp61
Sifus,
Having this vibration in my car. It happens after 100km all the way to my 180km cut.
1) Changed both rear drive shafts
2) Change rear wheels (borrowed)
3) balanced long shaft
4) Center bearings ok.
5) Tighten all main bolts on the drive train.
6) Vibration is on throttle, off and even with clutch in and on free gear
7)Changes gearbox mounting.
8) All bushes ok
9) Changes gbox and diff oil too.
Any similar experiences or commnets from the RED community?
My car is s a stock R33 GTS Series 2
i think its the front tyre problem...
try borrowing a set of tyre from friend
and balance it first before installing
Hi Doink,
Its not the wheels.
All tested , balanced and aok.
Vibration is from the midsection to the rear of the car.
Thanks for your input anyhow.
Write your reply...
