Profile California Ca400m Monoblock
general
Penang
http://akamaipix.crutchfield.com/products/2003/489/h489ca400m-f.jpeg
http://akamaipix.crutchfield.com/products/2002/489/h489ca400m-i.jpeg
http://akamaipix.crutchfield.com/products/2002/489/h489ca400m-o.jpeg
Key Features:
» 200 watts RMS x 1 at 4 ohms
» 320 watts RMS x 1 at 2 ohms
» requires 8-gauge power and ground leads
» variable 40-500 Hz low-pass crossover, 12 dB/octave
» variable bass boost (0-12 dB) at 45 Hz
» preamp- and speaker-level inputs
» 12-9/16"W x 2-1/16"H x 9-13/16"D
» Class AB
p/s: guys..I need pros & cons about this monoblock...tq
mmm.. thought you were selling this item.. didnt see the q about it..
I used to own a Profile California 4 channel amp. Decent amp for the price and looks nice. Sound isnt that great but was good for a beginner.
This monoblock is rated at 200w@4ohms and that is pretty low... a 2x50w amp will be able to bridge to 150w and a 2x75 amp can do abtou 250 easily.
Anyway, how much were u offered? If its really cheap then its good.
200w rms @ 4 ohm and 320w rms @ 2 ohm seems low. cant even go to 1 ohm. most subs nowdays can go to 1 ohm easily.
Calss AB means lower efficientcy compared to class D. Gets very hot when playing over somethime and comsumes more power than class D.
[snapback]913568[/snapback]​
seller offered me RM700++...anyway thanx for ur comments..
personally for that price, go for an epsilon or audiobank korean made amp (profile is also a Korean amp) of 2x100w or a min of 2x75w for a 4 ohm woofer...
If you are going for 2 subs with a final impedene of 2 ohms (2 4 ohm subs) then get a 4 channel amp n bridge it to 2 4 ohm loads...
