mohawk 6.5" Orange component system vs Lanzar VX6c component system
vitaminz
Segamat,Johor
dear frens,
which one should i go for ?if you, which one u choose?
1)Mohawk 6.5" Orange component
RM330
specs: ???
or
2)Lanzar VX6c 6.5" component system
RM350
SPECS
# One Pair 6.5'' Midbass: 6.5'' Midbass Driver
# Poly-Mica Coated Woofer Cone
# 1'' High Temperature Voice Coil
# Power Handling: 120 Watts RMS/240 Watts Peak
# Frequency Response: 50-22kHz
# Impedance: 4 Ohms
One Pair VST Tweeter:
# .5'' Mylar Dome Tweeter
# Neodymium Magnet
# Tri-Way Mounting System: Flush, Swivel, Surface Mount
# Power Handling: 50 Watts RMS/100 Watts Peak
# Frequency Response: 1.3k-22k Hz
# Impedance: 4 Ohms
One Pair Passive Crossover Network:
# Two-Way Passive Crossovers
# 12 dB Octave Slope
# Silver Plated Connectors
# Fully Protected Circuitry With dB Switch
# Includes Grills, Wires, Diagram, Template and Installation Hardware
erm...mayb i'll choose Lanzar 4 SQ....
i wan play char kei SPL...then i'll go 4 mohawk...
Orange 6.5" Component Set
Specs:
# 1'' Kapton Voice Coil (25mm)
# Magnet Weight: 13Oz (375g)
# Sensitivity (1W/1M): 89dB
# Mounting Hole Diameter: 145mm
# Power Handling: 75 Watts RMS/150 Watts Peak
# Frequency Response: 40-5kHz
# Impedance: 4 Ohms
One Pair Tweeter:
# 1'' Dome Tweeter
# 0.8'' Kapton Voice Coil (20mm)
# Neodymium Magnet
# Sensitivity (1W/1M): 91dB
# Mounting Hole Diameter: 46.3mm
# Power Handling: 100 Watts RMS/200 Watts Peak
# Frequency Response: 450-20k Hz
# Impedance: 4 Ohms
# 4.5k Crossover Point
# Includes Grills, Wires for tweeters, and Installation Hardware
ps: If possible, hear out an Orange Component set first, and then swap with lanzar on the same setup to decide which better suits you. It's unfair to conclude that Mohawk Orange is just for SPL while Lanzar for SQ.
Cheers
I've decided to install soundstream XSC.6.
Will do it once i have the time.. some where this week.. eh eh
yong, er...i guess so. cos the brochure states the figures. i just copy and type nia. hehe.
but maybe cos the tweeters are 1", bigger than the Lanzar 0.5", that's y can handle lower. dunno.
cheers
erm....coz i think tats mid bass freq....tweeter playing at tat freq can bcome fried kuey tiaw
... from the mohawk tweets specs, the crossover point is at 4.5kHz with -12dB slope.. it can also play 2.45 kHz but its attenuated.. the passives will ensure that the tweets will not kaput ;)
i'm not against lanzar or condemning the products, but its a brand known for SPL in the US, its not asscociated with SQ at all.. also many users in US hentam the lanzar lower end range.. FYI only :cool:
thanx pjam for the technical explanation...i shud take this down for future reference. hehe.
cheers
Write your reply...
