Branded Amplifier for sale
JBL CS60.4 4ch amp RM900
Power Output:
60 watts RMS x 4 channel at 4 ohms
80 watts RMS x 4 channel at 2 ohms
160 watts RMS x 2 channel at 4 ohms
≤ 1% THD + N
S/N Ratio: 86dBA (reference 1 watts into 4 ohms)
Dynamic Power: 145 watts at 2 ohms
Frequency Response: 10Hz - 27kHz (-3dB)
Maximum Input Signal: 6.0V
Maximum Sensitivity: 100mV
Dimensions:2.2" x 13" x 10.3"
fuse: 25A x 2
MAGNAT BullpowerFour 4 channel power amplifier RM650
http://www.magnat.de/dbimages/img_111720_Detail_Modell_col_0_pv300.jpg
Spec:
4Ohm
RMS/Max. output power (14.4V) 4 x 65W/130W
RMS/Max. output power (14.4V) 2 x 175W/350W
2Ohm
RMS/Max. output power (14.4V) 4 x 90W/200W
Loudspeaker impedance (stereo) 2 - 8 Ohm
Frequency response 5 - 100 000 Hz (-3 dB)
Total harmonic content < 0.05% (1 kHz)
Input sensitivity LOW LEVEL INPUT 250 mV - 4V
Input impedance LOW LEVEL INPUT 50 kOhm
Low-pass filter 50 - 500 Hz, 12 dB per octave
High-pass filter 10 - 250 Hz, 12 dB per octave
Bass boost 0…6 dB at 45 Hz
Supply + 12V (9-15V), minus to ground
Fuse 2 x 25 A
Sizes (W x H x D) 357 x 58 x 237 mm
Weight 3.5 kg
MAGNAT BullpowerOne Monoblock power amplifier RM680
http://www.magnat.de/dbimages/img_111716_Detail_Modell_col_0_pv300.jpg
Spec:
4 Ohm
RMS/Max. output power (14.4V) 225W/450 W
2 Ohm
RMS/Max. output power (14.4V) 400W/800 W
Loudspeaker impedance 2 – 8 Ohm
Frequency response 5 – 100 000 Hz (-3 dB)
Weighted noise distance (IEC A) > 100 dB
Input sensitivity LOW LEVEL INPUT 250 mV – 4 V
Low-pass filter 50 – 500 Hz, 12 dB per octave
High-pass filter 10 – 50 Hz, 12 dB per octave
Supply + 12 V (9 – 15 V), minus to ground
Fuse 2 x 20 A
Weight 3.4 kg
Please pm/call/sms: 012-2772443
Item above are brand new and stock in hand now~!
Power Output:
≤ 1% THD + N
fuse: 25A x 2
Spec:
4Ohm
2Ohm
Fuse 2 x 25 A
Weight 3.5 kg
Spec:
4 Ohm
2 Ohm
Fuse 2 x 20 A
Weight 3.4 kg
