F firdaus_khld Joined Nov 14, 2008 Messages 1 Points 1,501 Nov 14, 2008 #21 Bro ugpm. Give me your best price for waja 2007
drexchan 2,000 RPM Senior Member Joined Nov 23, 2004 Messages 2,907 Points 3,163 Location Bukit Jalil Nov 14, 2008 #22 Check your PM. Thanks!
drexchan 2,000 RPM Senior Member Joined Nov 23, 2004 Messages 2,907 Points 3,163 Location Bukit Jalil Nov 17, 2008 #23 CHASSIS, SUSPENSION & BRAKES GAB Suspension Products Ultra Racing Products CERMIC Brake Pads RS Performance Brake Pads ENGINE, PERFORMANCE & MONITORING MYTHELOGY Lightened & Dampened Crank Pulley SNOW PERFORMANCE Boost Cooler WORKS ENGINEERING Magnetic Oil Sump Bolt WORKS ENGINEERING Stage I & II Adj. FPR WORKS ENGINEERING Adj. Cam Gear WORKS ENGINEERING Silicone Products WORKS ENGINEERING Water Expansion Tank WORKS ENGINEERING Engine Oil Cooler Kit & Filter Relocation Kit CAMPRO Cam Valley Cover UtR Racing Development Cone & Panel Filters C-GROUND Customized Grounding http://www.zerotohundred.com/newforums/engine-and-performance/251374-elevo-voltage-stabilizer-with-grounding-cables.html AUTOGAUGE PErformance Meters EXTERIOR & LIGHTING Bumper Canard, Safety Reflector, LED Stripe & Numplate Holder AIR MASTER Fibre-reinforced Polymer Bodykit HELLA FF75 & FF50 Driving Lamps CCFL Angel Eyes STOCK CLEARANCE & PROMOTION SALES KONI H/L/S/H for Civic EK Universal Piping Kit JBL Audio Products Collector's Key Chains UtR Racing Development Short Shifters http://www.zerotohundred.com/newforums/interior-and-cockpit/238592-%5Bstock-clearance%5D-pro-lock-brake-clutch-pedal-lock-while-stock-lasts.html
drexchan 2,000 RPM Senior Member Joined Nov 23, 2004 Messages 2,907 Points 3,163 Location Bukit Jalil Nov 24, 2008 #24 All model sold out, but you can inquire or order. Thanks!
benccckl Known Member Senior Member Joined Oct 7, 2008 Messages 62 Points 1,506 Nov 24, 2008 #25 hw much to fit wira (crystal headlamp)
drexchan 2,000 RPM Senior Member Joined Nov 23, 2004 Messages 2,907 Points 3,163 Location Bukit Jalil Nov 24, 2008 #26 I only do ORIGINAL Headlamps.
