singmingtyre
Selling
Brand New
Portable Air Compressor / Tyre Inflator comes with 1 YEAR WARRANTY
Selling RM165
COD at below address ,
Courier available : Peninsula Malaysia Add RM 10
Sabah Sarawak RM 15
Interested pls call Sing Ming Tyre - 03-8941 1899
Whatapps 018 3196478 / 012-2238147
Address :
D-G-23-4-24 Block D,
Jalan PP32
Taman Pinggiran Putra
43300 Seri Kembangan Selangor
Designed to inflate any under-inflated tyres any time and anywhere.
Equipped with a pressure gauge for exact pressure requirements and also a deflate button if the tire is over-inflated.
Safety valve will release the air from the side of the compressor to prevent over-inflation if it is left unattended.
Powerful 15Amp motor - able to be use for all types of sedans, SUVs, 4x4 pick-ups, MPV up to 1.6 tons.
Inflate within minutes.
Supply to world leading car manufacturers as OE equipment.
Standard equipment in Lexus, Toyota, Daihatsu, Peugeot, Honda & etc.
Avoid the sweat of changing to spare tyres during puncture, especially for ladies driver.
No more worries when you have a flat anywhere, anytime
Able to inflate puncture tyre so that you can drive to the nearest workshop for tyre repair
Specifications:
Compressor: Mabuchi Motor, Japan
Weight: 1.5 Kg (1.7KG with packaging)
Size: 6.5cm(H) X 16cm(W) X 15.5cm(L)
Supply voltage:12V DC from car cigarette lighter socket
Maximum current: 15A
Maximum pressure: 7 bar / 100 psi
Operating temperature -30°C to +70°C
Performance 0 to 43 psi / 3 bar
Power Cable length: from the power inlet head till the box is 3M.
Hose length: from the pump hose head till the box is 0.5M.
Package includes:
This robust compressor comes in a neat carry nylon case.
Equipped 3 different types of nozzle such as air mattresses, balls, bicycles and etc.
Compact size easily stored in the vehicle.
