need help from all sifus
Jan 12, 2007
when i on ac my waja will overheating.temp will go fast.i think around 100 deg
but when i off ac suddenly temp will drop to normal position (btw quarter and half).what should i do???
jeffayn
621
62
3,028
Klang
You should get your mechanic to check it out. I think your colling fan might not be working in correct order,
Does your air cond feel warmer lately ?
redwaja
jeffayn
my ac still cold.i've see my jr mechanic but i'ts dont happen when he checking.he told me that my cooling fan is okay.i think i will go to sr mechanic as you propose.
thanks
mag9556
2,770
43
Trust ur self...dun trust on mech....they are mech not expert or god...
the car is yours...
the meter gone up only whn u stop ur car??
if yes..do it drop whn u start to drive back??
if yes... is the fan...
check the water also...sometime no water also can be like this...
thermostat kong also can..
Good day sifu
I tried do a search with regard oversize valves
Nothing much was discussed
What's the pro and con for increasing the diameter of the valves 1~3mm over stock
How much bhp one can expect to gain from 1.6 na or 2.0 na
Thanks
