my Rim's Problem or brake system?
skyrap
Ipoh~KL
i'm driving proton saga 1.3m.... from rim 13" change to Rim 15" ...
b4 i'm using 15" my car can stop very smooth, after change to Rim 15" and normal break it at the 110km/h, my car shake from front to back and can't stop well if emergency..but i confirm is not the rim problem nor the tyre...!! is it the spacer that put btw rim and the brake problem?? my 4 rim also put the spacer because the rim got 8 hole..
any sifu can tell me wat happening?? i went to motorsport shop and he said the problem is engine "mouting" thanks for ur reply sifu... :)
i doubt its the mounting..
it might be ur alignment lor..
it might be ur shock absorbers...coz when ur going fast and the absorbers doesnt work very well..so u will feel the car shake.
but if u cant stop and the shaking stops...it cud be ur brake pads
hehe.. brother. u are right....today just went to fix tomorrow only get car...
many problem happen in my front rear..
problem:
1) absorber mountingloosen that's y can't stop well
2) arm bush 3) bearing
4) the chain oil gear that stick with the rod to the disk brake spoil..
many problem ler.. dunno how much need to spend for all this item... :(
Write your reply...
