Monthly expenses for GT-R (R35)
it all depends what u want...personally think 6xx-7xxhp is good to drive on road....8xx hp still can drive on road but not too fun,not so comfort to drive
u can join gtr club malaysia for more info like others said...all info there
(5000-10,000km change)
transmission fluid(pentosin) 10L + clutch relearn rm2xxx
front n rear axle fluid rm3xx
engine oil n filter rm4xx
brake fluid rm1xx
to upgrade :
uprated brake line rm1xxx
brake pad rm1xxx up (depends brand)
air filter kit rm1xxx up (depends brand)
intercooler piping kit rm3xxx up(depends brand)
downpipe rm2xxx++ up
y pipe rm2xxx++ up (sus or ti)
catback system rm1x,xxx++ up (sus or ti)
uprated actuator rm2xxx++
uprated fuel injector rm3xxx++
heat range 9 spark plug. i.e hks,ngk racing (rm1xxx)
ecu reflash(cobb) nis-005 rm3xxx, nis-006 rm5xxx. if 600hp then need custom map rm1500
to protect engine/trans/cooling system(optional)
samco radiator hose =rm1000 +/-
Dodson low temp thermostat rm1000 +/-
uprated trans oil pan rm2xxx++
uprated engine oil pan rm2xxx++
things to well taken care
flywheel housing...bellhousing noise...to replace rm1x,xxx +/-
transmission assy..broken if u launch control....rm4x,xxx up
propeller carbon main shaft..if the joint having problem... rm1x,xxx to replace
thumbs up to the best answer coming from owner of 2 GT-R hehehehe!
When you get the R35, maybe you can consider swapping the original exhaust setup to a custom exhaust.
So far the best exhaust note I heard is from a matte green R35. I'm sure some of you are familiar with it. Not sure what custom exhaust the R35 is running on though. Anyone? :biggrin:
LOL,I won't build a horse or a bull because its top speed is slower than a MYVI
Uh... unless you misread the original statement, what you said is technically not possible.
I think you misread la. What the dude was referring to for the 'horse' or a 'bull' is Ferrari (horse logo) or Lamborghini (bull logo) and I assure you a Myvi is not faster than any car from either one of these car brands.
:rofl:
just get the greddy 4.1 stroker and hks gt-1000 kit and your the king lol
350++ km in 1 hours 15 minutes?hmm..with 800 horses..you will waste at least 15 mintes at melaka for refuelling, so, you still have another 1 hour traveling time. means you need to maintain at least 350km/h along the way..consider you need to slow down a bit on the corner to 300 km/h, you need to maintain at straight lane for around 380-400 km/h.. then maybe you need another 6 month at seremban or bofore it due to engine blown..in case if you not involve in any accident on the way..drive safely bro..i still lucky because still alive after totalled my previous car..now drive slow auto car only..
Another thing u missed...titanium balls to drive that 800hp in 1hr15mins covering 350km
better take air flight if wan fast
Hahahahaha. Seriously thats the most relevant thing to do. Exactly true, if want that fast just take the flight, why with the hassle endangering ourself and others to arrive faster :p This statement made my day. Hehe
Ehdrian : Thanks for the advice ,I will drive slower .Maybe reach KL in 2 hours .
IZSO: I don like european car except buggati and zonda .
Didie : take plane not fun ,driving is more fun .But I will drive slower .
if take flight also i believe need more time..15 minutes for check in, arrival also roughly 10 minutes to get out from plane to taxi, in case you dont carry any luggage.. taxi from lcct/klia --> KL around 45 minutes..if traffic is heavy, perhaps more than an hour.. plus the time it take to fly from JB - KLIA/LCCT..so, it also not really possible..
Tell me when you are on the way to KL.. i will miss the highway that day specially for you.. :biggrin:
I assume he means he wants to do the JB-KL run in 1hr 15mins. I believe its possible if he means toll to toll meaning from Skudai to Sg Besi. Very achievable in terms of travelling time as I'm not sure if an R35 at full blast all the way would need to stop for refuelling or not.
Not that I recommend doing such dangerous acts on public roads. If you do decide to attempt something which I'm assuming you've never ever attempted then please do so at night or early in the morning around 3-4am midweek. Then you'll encounter mostly trucks and if you drive with your highbeams on and keep flashing, they will mostly signal left to assure you they will not enter the fast lane. This is especially important in the Johor leg of the entire run where you only have two lanes. Once you've crossed into Melaka and the PLUS highway opens up to three lanes then there is a buffer should things go wrong. However, bear in mind the road surface changes at this point as well.
Before I forget, remember that Johor has strong crosswinds and despite the aerodynamics of the GTR, when you're travelling at triple the speed limit the car will rise slightly as air passes underneath and you'd want to take care when slowing down for sharper bends or whenever traffic conditions require you to do so.
If I were you, I'd buy the car first. Get used to it in stock form. Modify it and then get used to its power and then ensure you can handle it at high speeds.
No offence to any of the R35 owners but cars are getting easier to drive nowadays and a 800hp R35 will definitely be easier to drive than the earlier R32, R33 and R34 models which would need triple plate clutches, etc. That in itself will give an inexperienced driver the illusion that he is able to handle the car and push it harder than what he is capable of handling. Although most R35 owners are experienced drivers, at times the car does end up in the 'wrong hands' but that is the case for any supercar or even normal JDM and Continental performance cars. In fact, this is a good example.
---------- Post added at 04:02 PM ---------- 6 hour anti-bump limit - Previous post was at 03:54 PM ----------
BTW, I think the Toyota and Mitsubishi guys are still waiting on pictures.
yea...buy the stock GTR..drive it 1st n mod it slowly....
if u get the GTR n direct upgraded to 800hp...i can guaranteed the car will ended up somewhere else..muahaha:rofl:
ermm....2 hrs..yeah..probably achievable from sg besi toll to skudai toll..nearly been there done that
best of luck
btw..R35 do make my balls lil bit smaller during the first drive :biggrin:...sorry cannot comment on the monthly expenses...just a good thread to comment on and need to jot something on it
muzhaffar:THanks for the info
Pimpin: you are right ,the surface will have a big change while on one section of melaka if I am not wrong will be in cement road surface .For currently ,I own a EVO9 with 400++HP ,but with a 800HP or 1000HP GTR I need to be very very skillful .I will try to reconsider stock first because I like machines that is mod with it maximum performances .
---------- Post added at 05:18 PM ---------- 6 hour anti-bump limit - Previous post was at 05:17 PM ----------
Huakenny:haha,I know where the car will end up ( in my garage).
Apparently you've only just gotten the Evo 9 not too long ago and as powerful as it may be, you're talking about double that power. How fast have you driven the Evo? Actually, how fast have you driven, ever?
do you really asking for expenses for a GTR,especially R35?
It's not a middle-class choice of cars, i would say that me myself wont be able to afford it..
but i think, if you have the money to buy it in the first place, will u be worrying about the fuel consumption? especially when you're planning to go for 600hp, will the fuel be in the list of goals?
I guess you just playing with us..before it's the Evo9. At first i was really admire you since you can drop a big amount of money in parts even before you get the car, but now i would say it's just a internet hoax to brag about.
I will take back all my words if you can at least show me your E9 with all the modifications u made, if not u just wasting internet and bandwith of this forum for all of these nonsense - i.e, fuel consumption of GTR with 600hp.
if you really have the dough to do it, then good for u. but please prove it in the first hand that u really serious and not just want to be a keyboard-tycoon.
