Features
how to setup this features for Evo 8 MR
I want A to be 1 bar and B to 1.5bar
How does the scramble thingy works.... sorry for basic question first time user hope u guys understand.. thanks
Target Boost
* User inputs target boost level, and the EVC automatically adjusts pressure to reach desired level.
Offset Function
* If boost exceeds or does not achieve user’s target, boost pressure can be offset to reach desired level.
Map Correction Mode
* Boost pressure can be fine tuned for: Throttle Position, RPM, Vehicle Speed, Throttle Position + RPM, or Throttle Position + Vehicle Speed.
Dual Boost Mode Settings
* Separate A and B boost levels can be input independently from each other, and selected depending on driving conditions.
Scramble Boost Function
* When the scramble boost trigger is depressed a preset boost increase will occur for a predetermined time (0-60seconds).
* External Scramble Boost Trigger compatible.
Metric or SAE selectable monitoring
* Users can choose during initial setup metric (kPa) or SAE (PSI) boost pressure measurement for monitoring.
Warning Function with Boost Drop Feature
* A user preset warning level can be set where visual and audible alerts occur if the warning level is reached. Boost pressure can be preset to drop to a user defined level if pressure reaches warning level.
Analog and Digital Boost Monitoring
* Boost pressure can be displayed in both an analog bar graph format and a digital numerical value.
Additional Digital Monitoring
* Along with Boost Pressure two additional vehicle vitals can be monitored: Throttle Position, Engine RPM or Vehicle Speed.
Selectable Analog Monitoring
* The digital bar graph can be set to monitor: Boost Pressure, Throttle Position, Engine RPM or Vehicle Speed.
After Image Function
* Users can set the EVC to display the highest boost pressure reached for 3-seconds after the throttle has been released.
Data Lock
* To prevent accidental data changes from occurring, the EVC can be locked with a user defined four digit code.
