Mivec Gear ratio problem
All the sifu i hav another problem...
When im ideling i rev 3 times and it cut off at 6500rpm... after the cut off then is back to 8500rpm cut off...
Can all the sifu tell me wat is wrong ?
Maybe bcuz i cannot reach 180 is bcuz of this problem...
u better send ur car to a reputable mechanic to check...maybe ecu problem or mechanical...nothing to do v ur ratio
u can change gear ratio by changing the final drive inside the gearbox. not by changing intel chipset...
If change final drive.............all gear ratio will be change edi......hahha.....
the gearbox for turbo engine it's ?
ONly the way to go..........Try do OBD.....to dianogsis your engine system, see anything error........ ?......
really ,eh mivec juz only can go 180km/h ??? some more LSD ,than my auto mivec juz only can go 140km/h max loh so "cham"
Write your reply...
